Rti6 + RtiA1
williamgauci
williamgauci Posts: 88
edited December 2008 in Speakers
Need some advice on set up. My modest HT setup consists of a Yamaha 6080, I have a CSiA4 center with a couple RtiA1's as my sides and a couple of little RM rear surrounds from my first 5.1 set and using the psw10 that came with the RM set. So I picked up a pair of Rti6's cheap and i'm looking to incorperate them into my setup and probably set up for 7.1 finally. So my question is what's the better option, keeping the RtiA1's as my fronts and using the Rti6's as my surround sides or put the 6's in front and the A1's in back? Secondly, i'm using the fronts bi-amped off the extra outputs for the 7.1, will I notice a big difference in performance going to the single wire feeds now that i'm using the rear channel now?
_____________________________________________
Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R
Post edited by williamgauci on
  • ZOOPDOOP22
    ZOOPDOOP22 Posts: 158
    I think the rti6s have a larger mid, correct? If this is the case I would put them in front but they will need some break in time until they completely open up. As for the wiring.. I'm confused about your question. I would just run the r and l to your upper binding posts and your sbl and sbr to your lower posts.
  • williamgauci
    Yes, the 6's have a 1 inch larger mid. Sorry for the confusion on the last question, really all I was asking was that since I'm not going to be bi-amping the fronts because i'm adding the rear surround and going to 7.1 if i'd notice a real difference in sound from the speaker?
