IS IT WORTH MY MONEY OR TIME TO UPGRADE THE fX300I TO FX150
ralph perez
ralph perez Posts: 32
edited March 2003 in Speakers
HI
Sorry to bother , but here it goes anyway's. Currently my back center rear speakers are the Fx300i and plan on replacing them with the FX50i since the side surrounds are the FX500i, this way all 4 rear spakers will be mostly the same, and closer timber.
I bought the 300 at CC and it will cost me about $200 to upgrade from the 300 to the 50's, would I hear an improvement on the sound? Play 60% DVD 20% cd and 20% Radio.
Guy's any advice on wheter the EXTRA $200 WILL MAKE A DIFFERENCE AT ALL?
ANY OPINION WOULD BE GREATLY APPRECIATED.
Thanks,: :D
Post edited by ralph perez on
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2003
    Personaly I would get rt35's for the rears. I like the direct imageing for rear 6/7 channel. It mimics the front stage. Giving better sound for HT - fly by's - anything the comes front stage to the back stage and vice vera.
  • faster100
    faster100 Posts: 6,124
    edited January 2003
    to answer your question though, No i don't think going to the 50's wil yield better sound, The 300 and 500's are already matched, same tweeters .. the 50's are from the next line in the rti series from last year with the new tweeters... The 300's and 500's were just replaced by the 30's and 50's... They actually might not match as well if you move to the 50's.. basically the same speakers.
    I also agree with scott on getting direct firing speakers as REAR back speakers, alot of people like the di-pole on the sides and directs on the back center/s..
    what you have far as speakers now is all from the RT series and will match nicely with what you have, what you were wanting of course is from the new " i " series and won't match
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • begbie
    begbie Posts: 630
    edited January 2003
    For me,I like the fx surrounds for the sides and back. Setting the rear back surround in "BIPOLE' mode is a nice compromise between any debate of dipoles vs. directs.
    Is it worth the upgrade? Probably not but by looking at the equipment you got, getting the fxi50 gets you that much closer to a complete home theater system.
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
  • faster100
    edited January 2003
    He's already got a complete system, he wants to upgrade the backs to 50's from the 300's.....
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • begbie
    begbie Posts: 630
    edited January 2003
    You misunderstood faster100.
    He's got everything an average guy could possibly have (well maybe some separates) . So where do you go from there ??!
    Upgrading to the fxi50 could finish or should I say "balance" his setup ........for now ;)
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
  • ralph perez
    edited January 2003
    Hi begbie
    I just about have everything as a so called HT, that is the problem a Audio & Video phile is alway's trying to upgrade and make things a little better. (you hope anyway's)
    If I pass up the upgrading period on the 300 in March then decide to get the 50's (500) then have to pay top dollar. I could upgrade and if it doesn't make any significant difference in the sound, perhaps if CC would let me downsize to the 300?? That could work.
    What I am trying to do is upgrade the rear speakers, so that all of the 4 surround speakers are the about the same, but on the other hand does the center channel have that much sound out of them to make any significant difference in the sound between the 300 and 500. That's the question.
    Thank's for the replies, perhaps someone out there has had the same decision to make if so, would like to hear from you.
  • faster100
    edited January 2003
    I'f you need to get the 50's before the Circuit city 1 year upgrade is over then by all means... Then you can replace the other rears later to match the new "I " series that you will already have.. ie" the fxi50's,
    circuit city will not let you downgrade speakers... I have been buying and using the upgrade offer for years and know what i can and can't do with them,, Thats not one of them
    You are right in that the rear center wont be heard enough to tell the difference i don't think, its so fast when sound passes from left to right or vice versa.. people will say you can hear the difference but i beg to differ..
    Upgrade away, that year comes fast, i have upgraded my speakers about 6 times in the last year, one time for every speaker set i own, from the whole rt line i had to the new rti line and 2 subs i have had, Its fun, don't let the chance slip away
    however you might not be able to tell much difference you will be one step towards the new line which yields, new grills and logo's and most important the new wood exterior unlike the old plastic outsides..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • ralph perez
    edited January 2003
    Hi Faster
    It sounds good, but then I would be opening another can of worms. UPGRADE, UPGRADE, my wife will kill me if I started buying more speakers.
    Just a thought I am considiring on getting the LSifx for the side surrounds thru the web then moving myFX500i to rear center.
    That should be my ultimate speakers.
  • faster100
    edited January 2003
    Now your talking speaker mis-matching, i'f you go lsi and rt lines you will hear a difference.. different tweeters in the lsi's.. I think your barking up the wrong upgrade tree, Thats why i told the other poster that you already had a complete setup and moving to the 50's would not yield a big difference to at all... i'f wanting equal size speakers i would either 1. find another set of 500's or just get the 50's as they are as close to what you already have as you will get without going to far outside the sound matching..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited January 2003
    LOL! thats sorda like buying a 2003 dodge viper and putting a 1980's Nissan Truck with the interror.....LOL!
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • scottvamp
    edited January 2003
    Thanks MX - that puts EVERYTHING in perspective.
    I seeing things much clearer now.
  • RuSsMaN
    RuSsMaN Posts: 17,987
    edited January 2003
    LOL!
    NOT!
    Cheers,
    Rooster
  • scottvamp
    edited January 2003
  • MxStYlEpOlKmAn
    edited January 2003
    wha toilet water did u two grouches drink eh?
    I promised myself
    Damn you all! - ATC
  • ralph perez
    edited January 2003
    Hi Folks
    It seems that their is some activity going on on this forum. The 50 are only $240 more, but again do you really think the Ls series is that far of from the i series?
  • faster100
    edited January 2003
    Yes, The lsi's are that much different, hey its your money decide what suits you best and run with it, Thats all i can say... listen first then decide, i'f not return them
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • scottvamp
    edited January 2003
    faster is right - they are very different sounding speakers.
    Then again U might not even notice.
  • RuSsMaN
    edited January 2003
    If you use Q-tips regularly, you WILL notice. Totally different animals (speakers).
    Cheers,
    Rooster
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited January 2003
    Cheers,
    Rooster
    Ditto - confirmed it myself over the weekend. Sonic signature of the Vifa and the silk dome is different. Would be a timbre mismatch. Neither is bad, just different.
    SVS
  • ralph perez
    edited January 2003
    Hi
    It sounds like the best thing to do is to buy the fx1000 if it is available somewhere? it is the only one that will match my system.
    :cool:
  • scottvamp
    edited January 2003
    Originally posted by ralph perez
    Hi
    :cool:
    Fx 1000 is a long shot - not going to happen.
    Actualy Ralph fx500 -- fx1000 --rt35-- rt55
    Almost anything in the rt or rti series would work.
    Just not the LSi series.
  • begbie
    begbie Posts: 630
    edited January 2003
    Stick with the Rti series unless you want a complete Lsi series.
    Originally posted by faster100
    Thats why i told the other poster ......
    my name is begbie ......:( ..................................:lol:
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
  • faster100
    edited January 2003
    Sorry begbie, This thread is going in circles and i lost track..
    They don't make nor sell the RT line anymore, well atleast the fx1000, 500, or 300's.. best bet is used or get anything in the new line as a closest match... Thats about all can be said...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • begbie
    begbie Posts: 630
    edited January 2003
    No problem faster100.
    Well, we've beaten this thread like a dead horse. I only pray to the radio gods that Ralph will know what to do! ;)
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Velodyne cht12
    Polk psw111
  • ralph perez
    edited February 2003
    Hi, just an update
    Ordered the FX500i from pricesrite.com, It seems that they are searching for them? if they don't deliver then the FXi50 from CC.
    I should stay within speaker spectrum.
    Thanks Guy's for your input.
  • ralph perez
    edited March 2003
    Just received my FXI50 for the rear speakers. The rears are located 9 feet behind the sweet spot. It makes a difference in the rooms sound when compared to the FX300i.
