Media PC redo...
Lowell_M
Lowell_M Posts: 1,660
edited December 2008 in The Clubhouse
I'm currently running my old desktop PC (3ghz pentium 4 w/ 1 gb ram, 160gb HD) as a media PC. It's running kinda slow nowadays and still has all the crap we had installed on it before I started using it as a media PC.
Now, when I say media PC... All I am doing with it is using it for occasional web access through the TV, and use it as a music jukebox with Itunes. We also use it to show family pictures on the big screen, so I access the laptop that we have all of our photos on.
So.. I am thinking about tinkering with it a little and have considered rebuilding it as a Linux machine. I'm traditionally technically capable but it has been a while since I've messed with a computer and have never built a Linux machine.
Does anybody have any suggestions for what I might use regarding Linux to serve the same purpose as above? I may or may not continue to use Itunes as my media software. If I switch to something else I'll have the pain in the **** of writing all of the songs I ripped in apple lossless to CD and re-ripping them, as well as the songs I've bought in the past on Itunes.
So... wadda ya think I should do?
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • Face
    Face Posts: 14,340
    Before building a new rig upgrade your ram to at least 2 gigs.
  • Lowell_M
    Good point.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • ZOOPDOOP22
    ZOOPDOOP22 Posts: 158
    I 2nd the ram upgrade. If you were to go to Linux I recommend Fedora. However as you suggested it would be a pain with you apple lossless. Based on this I'd backup the music and go with a XP server edition. You could also easily set up a secure server that would stream your music to any connection you had anywhere if you wanted using other software. Not to hard to setup either.
  • Lowell_M
    Is there an Itunes version that will run on Linux or some other way to use itunes on Linux. The nerd in me has always wanted to mess around with a Linux machine for some reason. Otherwise I'll just rebuild the machine from the original XP disks that it came with and just not install all the crap thats on it now.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • fatchowmein
    fatchowmein Posts: 2,637
    a_mattison wrote: »
    For DRM m4a files, I thought you had an option to de-authorize a system and authorize another? Up to 4 machines I think. Don't quote me on it, though, but you may want to hit up the Apple website.
    As for Linux, Tom's Hardware likes MythTV but I hear it's difficult to configure if you're new to Linux programming. I have not tried it myself. See link below. There are recommended Linux distro for MythTV somewhere on Tom's site. Good luck.
    http://www.tomshardware.com/reviews/mythtv-convergence,1315.html
    Edit: I don't think there's an iTunes for Linux.
  • Lowell_M
    You're right. I just meant if I went with another media software and wanted to move to FLAC.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • fatchowmein
    One more thing. dbpoweramp music converter is free and has a batch conversion to change all your m4a to flac which will play in linux. But, if you're using iPods, forget about it because you can't play flac on it unless you erase the firmware and install a linux version.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Talking about linux what's the difference between Fedora and Slax?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Sami
    Sami Posts: 4,634
    If you want the latest packages readily available, Ubuntu is a good option for Linux distro.
    Linux + MythTV, MediaTomb or fuppes.
    OR
    Windows + TVersity.
