Double Polk PSW10
dalylaleahthor
Hello, I was wondering if anybody has a double subwoofer setup? I was thinking of getting 2 PSW10 to go with my Yamaha 663. Do you guys think it will be a good set up or should I spend my 250 and get a single sub and what sub should I get. My system is mainly for movies.
AS OF RIGHT NOW My system consist of
Yamaha 663
Samsung 52' LCD 120hz
Monitor 70 for fronts
CS2 Center
Monitor 40 Rears
PS3 for blu ray
and my monster hts 2600 should arrive on Tuesday
All comments and advice is appreciated.
Yamaha 663
CS2 Center
Monitor 40 Rears
PS3 for blu ray
Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either.
Post edited by dalylaleahthor on
Depends on your room size. The psw10 is just a basic sub. Good if its free, bad if you buy it. I would look at something else. However I have been able to tweek it but by no means will it rock your house. If you said you were able to get 2 for about 150 I would say go for it and place them one in front and one behind you.Retired Onkyo 520 (returned broken HK 247)
Now a Pioneer 1018
CSi3
2- RTI10's
2- R50's
2- Fxi3's
Onkyo 250W Sub
Polk psw-10
"Inch by inch lifes a cinch, yard by yard life is hard" -
No I get 2 for 250 new from newegg. So I guess I should save up for a Velodyne then huh:rolleyes:Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Stuff laying around. Too much to list but don't want to sell either. -
I'd save up for a single sub, and go with a slightly nicer one. I've never heard the PSW10 in person, but it has pretty bad reviews for the most part. It's just a basic sub though.
Look into the Velodynes, or something else. These Premier Acoustic subs are supposed to be pretty nice, and aren't that expensive either. Don't pay attention to the MSRP on that page. The PA-10 can be had for around 250-275, and the PA-12 goes for about 250-300. These would both be much better than the PSW 10.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
dalylaleahthor wrote: »Hello, I was wondering if anybody has a double subwoofer setup? I was thinking of getting 2 PSW10 to go with my Yamaha 663. Do you guys think it will be a good set up or should I spend my 250 and get a single sub and what sub should I get. My system is mainly for movies.
Yamaha 663
CS2 Center
Monitor 40 Rears
PS3 for blu ray
Get a better sub. The PSW10 doesn't have good low end or volume and it distorts very easy. -
well thanks for all the reply. I might just have to save enough to buy a Velodyne.Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
