Need MAJOR AVG Free help!!!!!
I-SIG
I-SIG Posts: 2,243
edited December 2008 in The Clubhouse
I'm home for Christmas trying to get my dad's computer running better. I used the Norton Removal tool from another thread to get rid of all the Norton BS on his machine. Prior to that I had downloaded the AVG Free file so I could do all the removal and installation offline and not worry about viruses.
Well, my dad's machine is trying to run the "index.php" file I download from CNET with Microsoft's Picture It! 7.0?????
How the hell do I get this file to execute? Do I need to download some .php installer? PLEASE Help!! I'm online with no virus protection! (I did download and install Firefox so I should be a little safer for now!)
THANKS SO MUCH FOR THE QUICK HELP!!!!
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • John30_30
    John30_30 Posts: 1,024
    That sounds oddball. php is a forum type scripting language like for this forum's software.
    Sounds to me like you downloaded the wrong thing. Are you trying to run a flash video from CNET or something?
  • markmarc
    markmarc Posts: 2,309
    Wes:
    My success with AVG Free is based on installing after nuking and repaving the hard drive. Unfortunately, no matter how good the removal tool is, I have seen tentacles of programs still around. If possible, backup the documents before doing anything else.
    I hope someone else can give you the answer you need.
    Former Staff Member TONEAudio
    2 Ch. System
  • Motzart
    Motzart Posts: 1,075
    Sounds like something stuck in the registry from a previous install.
    Ashampoo has a few programs I use to clean things up.
    Ashampoo Optimiser might help?
    http://www2.ashampoo.com/webcache/html/1/product_2_1406__.htm
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • Motzart
    markmarc wrote: »
    Wes:
    Yes those are junk "Calls" to the registry from previously installed programs.
    Even tho you un-install programs there is ALWAYS something left in the registy.
    Thus when ya boot the computer it's still looking for the old program and calls to it.
    Fusterating but that's Microsloth for ya!
  • I-SIG
    I-SIG Posts: 2,243
    I tried deleting the .php extension in the Folder Options so I could choose to open it something else, like IE, but it wouldn't run. It was just a loop where I kept clicking open, etc... and went back to the same thing.
    Wes
  • Motzart
    I-SIG wrote: »
    Wes
    This Windows XP?
    Do you have a install disk for it?
  • I-SIG
    I-SIG Posts: 2,243
    We can't find the disk. :(
    It is XP Home running on a celeron.
    I downloaded the shampoo program and am about to run it.
    Wes
  • Motzart
    I was gonna say at worst you could reinstall XP and not lose anything.
    Been there and done that. :(
    It would fix any problems it finds.
    Hafta see what happens after a registry fix.
  • I-SIG
    I-SIG Posts: 2,243
    I tried opening the file with notepad and just got junk. Should I try wordpad MFC application? I'm redownloading the index.php file.
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    I figured it out!!!!
    Apparently the AVG file is compressed with a program called 7-zip and for whatever reason the self-extractor wouldn't work for me. So, I downloaded 7-zip, extracted the files to a folder and found the setup.exe file and ran it.
    AVG 8.0 Free is up and running now. :D No more Norton!!!
    Wes
  • Motzart
    Glad ya got it fixed!!!
    AVG is great I've been using it for many years now.
  • I-SIG
    I-SIG Posts: 2,243
    Yeah, I've been using it as well for a few years now. Between AVG, Firefox, SpySweeper, and the NoScript add-on I've been virus free for a couple of years now, even going to some questionable places every now and then.
    Wes
  • Motzart
    I-SIG wrote: »
    Wes
    ****? Pirate sites? :eek:
  • petrym
    petrym Posts: 1,912
    Motzart wrote: »
    ARRRRRRRRRRRGGGGGHHH, prepare to be boarded laddie!
    Oops, did I say that out loud... :o
  • seeclear
    seeclear Posts: 1,243
    I-SIG wrote: »
    7 zip is also a great little (free)program.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
    billbillw Posts: 6,846
    If anyone else has this problem, note that AVG offers a direct download of the original .exe file.
    http://www.avg.com/filedir/inst/avg_free_stf_en_8_176a1400.exe
    For rig details, see my profile. Nothing here anymore...
