SurroundBar 360 input types
rgidspolk
rgidspolk Posts: 2
Can someone explain the correct settings for blu-ray inputs to a surroundbar 360 please.
I have a samsung BD-P2550 hdmi output connected to a Sharp Aquos hdmi input. The Sharp optical output is hooked to the Surroundbar's input. No audio when watching the blu-ray. (works fine watching HDTV)
Added optical output from the samsung blu-ray to the surroundbar input aux1. Now I get audio. Is this the correct connection?
Further, the samsung blu-ray offers PCM, Bitstream-recode, and Bitstream-audiophile. Recode is described for - optical input that can decode DTS. Audiophile is described for - HDMI 1.3 receiver which has DTS-HD decoding capability.
Also available is 96Khz or 48Khz PCM sampling rate.
I have no clue what to choose.
Post edited by rgidspolk on
  • shiarua
    shiarua Posts: 13
    edited December 2008
    Optical cannot transmit bitstream-audiophile as it is referred to there. Only HDMI can transmit bitstream-audiophile, which is the DTS-HD Master Audio (Highest resolution audio 24-bit/96KHz @ 8 channels or 24-bit/192KHz @ 2 channels).
    In this case, you do have the correct connection. You should chose Bitstream-recode or PCM if recode doesnt work. Chose 96Khz, and if that doesnt work chose 48Khz.
  • dorokusai
    dorokusai Posts: 25,631
    I agree with Shiarua concerning DTS-HD and the connections you chose are correct. You could also use the coaxial digital input in lieu of the optical input.
  • rgidspolk
    rgidspolk Posts: 2
    Thank you for the information.
    What is the benefit of switching to (or adding?) a coaxial digital cable?
    I assume the cable would be from the blu-ray to the polk?
    BTW, using the recode setting at 96Khz, the system sounds great.
    My wife even commented on the audio of "the dark knight".
    Thanks,
    RG
  • dorokusai
    No benefit, just noting the option. Yes.
