Need a stand to hold LSiC
need a new stand..closed back to be able to fit the lsic center channel...please help...i need the overall length to be less than 65"..thanks
Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
Post edited by eclimax13 on
I was using a Sanus stand for my lsi. Now i went for a wall mount by www.bracketsandstands.com. I was able to get a higher mount at ear level. If you are looking for a height of 65"that maybe hard to find with a stand. The reason i went with the bracket.
Good luck and welcome to the site.Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
Thanks to you posters. I really needed a center channel stand that would work but wasnt ready to start looking yet.
This stand from the above website in silver is 22 dollars and perfectly suits my needs. Soon I'll have a proper sound stage. -
sdschwendener wrote: »Thanks to you posters. I really needed a center channel stand that would work but wasnt ready to start looking yet.
I have the same mount for my center channel. I have no complaints, it's built well, and is easy to mount.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
thanks for the help guys...the lsic actually has mounts on the back of it but due to my setup, i cant move the tv back enough to mount it to the wall and have the sound not be partially blocked...i have a 67" samsung dlp...i found the sanus cfv69 but its 69" wide and id like to keep it a little shorterTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
Oh...you're looking for an component shelf. I thought you were looking for a speaker stand. Are you looking for something with a wood finish, or more of a contemporary look?
Try looking here.
Those are mostly more modern looking, but they're pretty nice.
If none of those are to your liking, Crutchfield has some pretty nice ones.The nirvana inducer-
ya..i need a whole component system no more than 21" high and less than 69" wide...that can fit the size of the center channel..and i have a contemporary one now..but im sick off seeing all the wires, thats why im looking for a closed back...thanksTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
