Speaker change
Mike Kozak
I am thinking of getting rid of my Paradigm Mini Monitors v.4 speakers and moving to the Polk RTiA1 model. Thoughts on this? Good move, or is this a dumb question?
Thanks and Merry Christmas everyone!!!!
Post edited by Mike Kozak on
Can you go listen to the RTiA1? Best way of knowing if you'll like them more._________________________________________________
I am thinking of just buying them anyway, they got great reviews in Sterophile this year (August) I think -
Mike Kozak wrote: »I am thinking of just buying them anyway, they got great reviews in Sterophile this year (August) I think
Based on a quick price comparison, do you really think this would be worth the upgrade?
Paradigm's have a good rep - as does the RTiA1 -but both are in the same ball park for MSRP.
Maybe you should consider going up the RTiA3 if you are set on a bookshelf.
And depending on your listening tastes, maybe the LSi7?
From what reviews I could find on the v4s, the RTiA1s may be more 'revealing' in the top end - but I'm not sure, given the cost, you'll get a dramatic step up in SQ.
Just stirring the pot....
Thanks Eric, good info and I tend to agree, just thinking aloud here. The RTiA3 may be the way to go, but I will also take a look at the LSi7. I am a speaker junkie!!
But I also want to pull the plug on some Maggie MMGs!
Mike Kozak wrote: »But I also want to pull the plug on some Maggie MMGs!
Geez, and I thought I was a speaker '****'
Indulge!!!!
I would listen to the RTiA3's and LSi7's......if you can afford it, LSi9'sLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
