S6 Driver break in
Dr.Strangelove
Dr.Strangelove Posts: 3
edited December 2008 in Speakers
Hi all...
Just received my replacement drivers for my S6's...How, or should I "break" them in? Bear with me as I am a novice when it comes to audio "speak"! Thanks in advance.
Oh...I also purchased a pair of S10's off ebay for $71...Deal or No deal? And yes they apparentley work well.
Post edited by Dr.Strangelove on
  • ben62670
    ben62670 Posts: 15,969
    Just run them moderately. Some guys stick them in a closet with a blanket over them. Which drivers did you replace?
    Ben
    Ben
  • Dr.Strangelove
    The 6.5" powered driver in the S6 speaker.
  • ben62670
    It should be fine in about 3 hrs.
    Ben
  • dorokusai
    dorokusai Posts: 25,577
    Or 15 seconds.
  • Igo
    Igo Posts: 411
    Most drivers will do 95% of their wearing in during the first couple hours of moderate play. Sometimes the difference in sound is huge.
    ...Link to my System Showcase...
    "ES - Kind'a simple but I like it"
    Sony ES STR-DA4300ES 7.1
    Sony ES SACD SCD-C2000ES
    Sony 400 Disc CD CDP-CX455
    Infinity BU-2 Sub-Woofer
    Polk Audio RT800i Towers
    Polk Audio CS400i Center
    Polk Audio FXiA6 Surrounds
    Sennheiser HD 280 Pro Headphones
    DH-Labs T-14 Speaker Cables
    Panamax Max 500 DBS Line Conditioner
    Panasonic TH-50PZ85U 50'-Plasma
    Play Station III - BluRay
    Logitech Harmony 550 Remote
    Logitech diNovo Mini Keyboard
