What kind of connector for Polk CS2?
I am thinking about buying a speaker wire connector for my CS2 speaker. I was wondering what the best kind would be. Also, I am not looking to spend too much money on it.
Thanks.
Post edited by nileriver23 on
Welcome!
    edited December 2008
    Banana plugs are the easiest. Make sure your receiver can use them. Also some Polk's have little plastic inserts in the binding post that have to be removed before using bananas.
    Ben
    Ben
    Are these a good choice? http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=4#feedback
    Also, I am planning on getting some Polk floorstanding speakers as well (probably something like the R50's, R300's, or Monitor 50's or 60's), and I am wondering if these will work for them as well.
    Search for GLS Bananas on Ebay. They are very good connectors on the cheap. That is what I have been using. I think the store is speaker repair shop?
    Ben
    Ben
    I am using those banana plugs on monoprice and like them. They are nice and heavier than they look. I would go with monitor 50's or 60's because it would match your center and the monitors are a better speaker than the r series IMO. I have the monitor 50's and enjoy them. Hope this helps and Good luck with your choice.
    Heck, go with the 70's!!!! I have them and they play very nice with my CS2.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
Welcome!
Welcome!
