Help with center channel.
rsway77
rsway77 Posts: 2
edited December 2008 in Speakers
First of all I would like to applaud all the polk owners here in the form. Seems like everyone has been so helpful to each other, so that's why I'm here to ask you experts.
So here's by problem. I bought a pair of RTi4s for my fronts and I decided to match it with the CSI a4. After reading all the post, they seem like they should be a good match..but they are not, well not for me. I'm running the speakers through a yammy 663 (which I heard was really good too). So my problem is that the RTi4 seem clearer at the higher end, while the CSI a4 sounds a bit muffled. I tried swapping the CSI a4 and the left front RTi and that did seem to make a little improvement on the sound coming out CSI a4 but not that great.
So my questions are
1) Is it possible that the CSI a4 got damaged during transport, and would a damaged tweeter be very obvious to detect?
2) Is the center channel sound supposed to sound a little different compared to the front speaker especially when listening to test tones?
3) Is the older RTI line slightly brighter than the RTi A series? or do they use the same tweeter?
Much appreciated
Post edited by rsway77 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    First off Welcome. :)
    Did you balance the system with an HT Setup disk like Avia and sound meter? All system should be balanced for proper sound.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • curved
    curved Posts: 664
    Agree with Disneyjoe - you should run the setup on the AVR to configure it properly.
    The A4 will match just fine with the RTi series.
    It's possible that it got damaged....although I would think it would be a driver and not the tweeter (shifting magnet). Is there any visual damage to the tweeter?
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • leroyjr1
    leroyjr1 Posts: 8,785
    rsway77 wrote: »
    So my questions are
    Much appreciated
    I had the same problem when I was running my Denon 1708. Took it back and got another one, still same thing. For some reason that model Denon was made that way.
    Heres the THREAD
    http://www.polkaudio.com/forums/showthread.php?t=66370
  • seeclear
    seeclear Posts: 1,244
    curved wrote: »
    Loose wire inside?
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • rsway77
    rsway77 Posts: 2
    Thank you all for responding.
    I don't have avia or a sound meter. Is it hard to do? Can I get on at radio shack or somewhere? Is there a link on how to do this?
    There's is no visual damage to the speaker, but the box that it came in wasn't in the best condition. I tried covering each of the speaker ie tweeter/mids with a pillow as directed by the Polk Tech support and it seems like all the speakers are working
    I reran the YPAO a couple of times and it sounds better on my most recent try. The first couple of times it detected the front and the center as large, but on this very last time, it detected the front as large but the center as small, which is kind of strange.
    Finally, how do I check if there's a loose wire. Wouldn't that mean the sound should cut in and out?
    Thanks again for everyone's help. I'm very glad I choose polk not only for the speakers but for people that already own them, who are all so willing to help out.
  • Igo
    Igo Posts: 411
    Check the polarity of your wires on the back of the center then do a manual calibration. Trust your ears.
    ...Link to my System Showcase...
    "ES - Kind'a simple but I like it"
    Sony ES STR-DA4300ES 7.1
    Sony ES SACD SCD-C2000ES
    Sony 400 Disc CD CDP-CX455
    Infinity BU-2 Sub-Woofer
    Polk Audio RT800i Towers
    Polk Audio CS400i Center
    Polk Audio FXiA6 Surrounds
    Sennheiser HD 280 Pro Headphones
    DH-Labs T-14 Speaker Cables
    Panamax Max 500 DBS Line Conditioner
    Panasonic TH-50PZ85U 50'-Plasma
    Play Station III - BluRay
    Logitech Harmony 550 Remote
    Logitech diNovo Mini Keyboard
  • comfortablycurt
    comfortablycurt Posts: 6,745
    I had the same problem with my Onk' 606 when I first got it. I ran Audyssey, and it sounded great for the most part, except for the center channel. So I just went into the settings and turned the center channels level up a bit higher until it sounded right to me. It didn't mess up the other settings that Audyssey made either, and it's dialed in perfect for my ears now.
    I'd recommend trying the same thing.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
