RTi10's and RTia6 are they timber matched.
wowthatsloud
I have the RTi10's with the CSi3 center and want to up grade to the RTiA6 because the CSi3 seems a little weak with the 10's, are the two series timber matched.
Post edited by wowthatsloud on
Perfect combo!!Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Yes, they are timbre matched.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's -
Not the same series but close enough where you may not notice a difference.
They'd be a great match. The RTi A series is basically the updated version of the RTi's. The use the same drivers, but the cabinet design is a bit different. So your center channel should be sounding great if you get one of those.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
