Fixed l pads
Kane
Kane Posts: 2
Hi
What wattage resistors should I use for a fixed l pad? I Google'd a bit and all I got were off sounding numbers that I can't find anywhere.
Could anyone also link me to or post a formula/calculator to find the resistance values?
  • Eric W
    Eric W Posts: 556
    edited December 2008
    Depends on what kind of speakers, what application and what kind of amplifier you're using...
    -Eric
    -Polk Audio
  • Kane
    Kane Posts: 2
    I know..but how would I determine the resistor values and wattages knowing the driver specifications? I'm not looking for someone to give me the answer, just need to know how to figure it out.
    I've also heard that I could use resistors in series before the tweeter's crossover components, and that each ohm of resistance is about 1dB attenuation. Is this correct? I assume I would need to add the resistors on the positive end?
