Bummer!
hearingimpared
My Monster Power center took a dump on me. Monster doesn't repair the product they replace it which for the price they want is pretty cool even though I don't have the funds to do it right now.
Problem is that I can't listen music. I don't have enough outlets to power the equipment and I'm really against power strips.
Anyone have any ideas on how to get around this until I get the moola to get the new power center?
Thanks,
Joe
Thanks,
Joe
Post edited by hearingimpared on
I used a belkin power strip once.....its the one to use if your going to go the cheap power strip route. its not ideal, but you will have some decent protection for the gear if there is a power spike.
talkin like 30 bucks or so. I'll find a link if I canLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Thanks Louie.
http://catalog.belkin.com/IWCatSectionView.process?Section_Id=207100
a little more than I thought, but the 8 and 10 outlets ones with the remote on/off are more than intriguing. might grab one myself for the theaterLiving Room 2 Channel -
also,
http://cgi.ebay.com/New-PureAV-HDTV-Surge-Protector-by-Belkin-8-Outlet_W0QQitemZ220327093402QQihZ012QQcategoryZ67781QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
this happens to be the one I used to use for my 2 channel. it handled a Carver m4.0t amp and the rest perfectly fine. It was replaced by a Monster 5100 (I think the first one, you had series 2 with the blue lights right?)
truth be told, not a real audible sound difference at all, I did like the added protection, more purpose built, and ability to read the voltage and amps in case there was a problem.....but other than that, no audible difference really. 24.99? think you can schwing that brothaLiving Room 2 Channel -
Sucks to hear Joe
Joe, get your big arse down to Home Depot & pick up an el-cheapo power strip to hold you over. Hell, it might make your TT sound even sound better!!!!
Sorry to hear the Monster cut out on you."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Joe, I'm sorry to hear that. If you are interested, I have a MP HTS-1600 you are more than welcome to use until you can find a permanent replacement. Just say the word man....~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Circuit City UPS starting at $30 +-. Also numerous surge protectors.
Since Monster replaces them for free, why do you need funds to get it replaced? From my experience their customer service is excellent.
Monster is not replacing mine for free. I purchased it from a fellow Polkie so they are charging for the replacement.
if you really need to go with a power strip Belkin makes some nice ones as does tripplite I've owned both, no problems with noise check the packaging, the higher the joules rating the better the protection, also they have a guaranty. The strips I bought had a $50,000 and $75,000 on all products connected to it.
yeah replace it with a PanamaxPolkFest 2012, who's going>?
Why would you want to give any money to the corporate thug that is M?
I'm sure you can find something else that will do just as good a job & cost a lot less to boot.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I'll have to check some of those links out. I've been looking for a good surge protector. I'm just using a cheap one right now...and I think it's time for an upgrade.
Sucks about your powercenter getting fried. That just gives you an excuse to upgrade to a better one though.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
go solar.:cool:
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
If you don't return my phone calls, the power center isn't the only thing that's going to be broken.Political Correctness'.........defined
President of Club Polk -
Sorry to hear, from what I read here.... Tom or Jesse got you covered. Way to go guys two thumbs up.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I agree with Cathy, I wouldn't give Monster a dime.
Check out Pure A/V or PS Audio.
But first, give Jesse a call."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
i got my moster 2500 replaced under warentee even know it was out of warentee for a few years.
I maybe able to repair the unit for little to nothing (part charge only free estimates) if you wish.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Hey Joe, I still have that bag of 45's for you. I have not really looked at the titles, but most are in nice shape w/ jackets.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
pure A/V PF60
Fry`sCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
F*ckit! I'll bring a direct feed from utility TX to the rig.....
Dude whack him a few times for me too:D
Love ya Joe:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks Mike.:) -
If you don't return my phone calls, the power center isn't the only thing that's going to be broken.HeHeHe
Love ya Joe:)
"Bailiff wack his pee pee!" Cheech & Chong -
I'll whack my own Pee Pee thank you:eek:Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Whoa, whoa, whoa! Slow down there Yom Kippur. TMI.....
Hey Joe, I never did get back in contact with you that night. You straight?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
go solar.:cool:
But don't forget to use a solar flare suppressor.
Monster cable equipment? :eek:Vinyl, the final frontier...
