need help choosing a sub
senorpumba
ok so i am looking into either a fosgate 12inch power series which its a fosgate t112d4 or a polk sr104-dvc. so opinions/imput would be liked.
Post edited by senorpumba on
What kind of music do you listen to, and how do you usually listen to it? Are you looking more for a big quantity of bass or high quality bass?
I just looked at the two different ones you mentioned. Going by the descriptions, I personally would go with the Polk. They do appear to be fairly equal though. I prefer the sound of a 10 to the sound of a 12 though personally...which partially influenced that choice. Ten's just have a tighter, less boomy sound to my ear.
What kind of amp are you planning on driving them with?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
im not to sure about the amp i am getting the sub for christmas and im going to save up for an amp. i listen to a lot of rap and rock/country.
but for a amp i was thinking about a rockford T5002 but if i go with a polk ill probably get a polk amp to mach. i like to stick with the same brands unless you have a suggestion about a good amp that would power either one of thoes.
or maybe a MTX TE601
I was running RF punch power dvc's before switching over to MTX 9500 . RF would be my choice. They hit very hard. As far as amps RF bd series would be a great choice.
but now which sub should i get? i found a refurbished fosgate t210d4 they dont have them on there web site but they do exist. or the polk sr104-dvc
