Panamax 5100 or Monster 2500/2600
criverajr
Fellow Polksters,
I would like to get one of these two units for my HT Setup, have the specs for both, but they seem similar. Has anyone had any experience with either one of these or can recommend one over the other. The AV shops I've been to have mostly all like the Panamax, what do you guys think?
Post edited by criverajr on
I have the HTS-2500, works great and runs great, I've had no problems with it. I've heard the Panamax is a very good unit as well. Can't say I noticed any difference in sound quality after wiring it in though.
You cannot go wrong with either.
Peace out~:DIf...
Ron loves a film = don't even rent. -
I have the HTS3500 and have no complaints. It's a great unit.
I want one of these also, I live in a 1940's ?? House and think some power =management would be in orderMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Panamax all the way.
I just purchased a Monster 1100 from best buy. Are they pieces of junk comared to the other 2? Is all I bought a $200 surge protector?
Just got the Panamax in very nice unit and fits into the systems flawlessly, the monster was nice but the all black panamax looks very cool, and did cut out some if not all small humming noise
