towers
Im looking to get rid of my fx300i rear surrounds and get towers. I like 5 ch stereo music and like it loud. I now have plenty of power to play around with. Would the Rti 12 match good with my speakers? Ill make them my new fronts and move the rti150's to the rear.
But I was also wondering does the monitor series match up well also. They seem to be alot cheaper.
If I go with the rti12 Ill be powering with my xpa5 using only 2 ch so they should rock. Watcha think.
Post edited by selkec on
Welcome Selkec. Stick with the RTi series.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I think you will like the RTi12`s !
What`s not to like....they rock !!
Great for HT and music....IMO
Welcome to the frayCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
For the best match, you'd probably should stick with RTi series, but putting RTi12 in the back would be such a waste (just my opinion). Why not go with RTi8 or RTi10? These are the smaller brothers to RTi12.
Or better yet, go with RTi100, to match your fronts.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I thought he was going to put he 12`s up front...
you are correct....12`s in the rear would be a huge waiste
even the 10`s might be overkill....nice, but maybe too much
I have never used 7.1 for music though !!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Yeah, Ill put the rti12's in the front and move my rti150's to the rear. I think the rti12 will have more bass and sound a little better than what i currently have even though they rock. I upgraditis right now which explains the 2 new emotiva amps. By the way are the rti12 8 ohms. I kow my rti150s say they are but I hear they actually are not. Does anyone know the real ohms of the 150's or how can I measure it. I have a volt/ohm meter.
