Rattle in psw505
tytus45
tytus45 Posts: 14
I think i have it figured out. When the sub is playing it sounds like there is a rattle coming from inside. I listened to the driver tested it that is fine. My thought it is the leads from the amp to the sub itself. When I invert the sub and play it the rattles goes away...My question is how to secure the leads inside the box to eliminate the rattle..Silicone?. staple tack to secure? Looking for some ideas...thx
