XO parts in!!!
RandyWilliamson
Received:
4 12uF sonic caps
4 mills resistor
sonic solder
2 .33uF Dayton caps.
Glue gun.
Can anyone help out with tips especially for glue I don't want to overdue it...and I definitely don't want to accidentally skip glueing something really important.
My current plan is to emulate the original glueing spots.
The dayton .33uf caps look really small this is normal or did I buy the wrong caps?
4 12uF sonic caps
4 mills resistor
sonic solder
Glue gun.
Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss"
Benq W5000
Post edited by RandyWilliamson on
They should be 33uf, and not .33uf.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
If you need a hand, I may be able to help you out next weekend."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Dammit I eff'ed up.
Got any links to order the a 33uf or 34uf ? the closest I think I've seen is 30uF.
What an a-pipe move....just blew a perfectly good weekend project.Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
"Leaning back like a maxwell tape commercial listening to pure polk bliss" -
Amazing those don't appear here:
http://www.parts-express.com/dayton-metallized-capacitors.cfm
and I would have caught my stupidity had they! Well actually I called it in...and told them specs...so....ah w/e.
Thanks....anyone with glue tips do's or dont's?Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
Don't over do it."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What model are you working on, Randy?
I just installed new capacitors and resistors in my 7Bs (my first such project ever) and I didn't use any glue.
I thought about it, but the components weren't glued down in the first place. Plus, the new capacitors are so much larger than the old ones that they can't sit in the same place on the board: in fact, they would cover up the holes where the leads need to go, if they were sitting right down on the board.
I'm just happy that glad my vast experience of rebuilding one set of crossovers will be of help to others.
Monitor 10's w/10a XO well I read somewhere here somethings do have to def. be glued due to the harmonics in the box or pressure w/e....
I'm gonna try and glue as much down as I can.Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
You will want all components to be tight, so to speak. Use just enough hot melt to hold the caps and resistors so they don't vibrate. I used some good quality foam tape between the board and the caps and resistors. Where the caps and resistors are close enough or touch lay a bead of hot melt so they are bonded together.
Hope I have been a help.
Drew -
Beautiful
Awesome THANKS TO ALL.Cool stuff: Adcom GFA-555, GFP-710, Oppo BDP-83, Monitor 10's w/RDO198s, rebuilt and modded XO: Sonicap/Mundorf topside, Daytons Low.
Benq W5000
