Upgrading the SRS
Texas42
Texas42 Posts: 410
edited December 2008 in Vintage Speakers
As I mentioned in a separate thread a couple of days ago, I was lucky enough to come by a pair of SRS in average condition but now it is time to get them to their best. I ordered some new grill cloth for the front grills (not sure how one would go about re-placing the grill cloth on the sides of the speaker without literally taking them apart so I'll leave them alone). I also found a MW 6503 driver on ebay reasonably priced to replace the one I have out now.
At this point, I guess the next thing to do would be to upgrade the crossovers. Is there a 'preferred' method (certain caps, etc) recommended for this? Or perhaps a place to send my crossovers off to to have them updated? I'm guessing the crossover board simply unscrews from the front of my SRS (or is any of it on the back terminal plate?). There is a place in Texas that specializes in crossover repairs (GR Research...haven't used them but they look like they know what they are doing. Whether they know anything about SDA crossovers, I don't know yet).
Lastly, I'm guessing after I get my crossover running up to speed I should replace all the tweeters from the translucent yellow ones I have now to the black ones.
Any other upgrades I should consider? I tried several searches but it always comes up with 500+ threads, none of which seem to be what I am looking for. Thanks in advance for any assistance.
Regards,
Dave
Post edited by Texas42 on
  • ben62670
    ben62670 Posts: 15,969
    These are the big SDA-SRS's?
    here is a link to a thread of the 1.2 XO's I did for a fellow Polkie.
    http://www.polkaudio.com/forums/showthread.php?t=72952
    Yes the XO is attached to the front Plate;)
    Ben
    Ben
    heiney9 Posts: 25,509
    Dave,
    There is atleast 1 if not a couple more threads on removing the side panels for re-clothing. It is a painstaking and slow process but it can be done. You are correct there is a bit of dis-assembly involved.
    I believe Darqueknight did a "how-to" about 3-4 years ago with pics and a step by step process and Lasareth may have a step by step process thread as well.
    Good luck
  • BAD ASP
    BAD ASP Posts: 361
    On the crossover upgrades I would say go for it. Ben did a first class job on mine and the improvement is SQ is spectacular. It's been a couple of months now and the sound continues to blow me away. Big plus in performance with out question.... jmo....:D
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
