Best Center choice for RTi A7?
trinidesignz
trinidesignz Posts: 97
edited December 2008 in Speakers
Should I go with the Csi A4 / A6 I was looking at Polk Audio system bundles and they had the CSi A4 paired up with RTi A5 / A7 and the CSi A6 paired with the Rti A9.
I'm wondering if the A6 will be too strong for the A7?
Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Velodyne DPS-12 (Sub)
EMOTIVA XPA-5 :D:cool::p;):)
Post edited by trinidesignz on
  • curved
    curved Posts: 664
    Get the A6 if you have the room.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • thsmith
    thsmith Posts: 6,082
    I think it depends on your sub and how much power you you plan to run. I have the CSiA6, should be the last center I will need.
    Polk Direct on ebay had some great prices.
  • trinidesignz
    Yea Curved I got crazy room, and thsmith I got Velodyne DPS-12 and receiver denon 3808ci. Also I'm buying all my speakers from polkdirect I ordered the rti A7 lastnite.
    Samsung-55 LED
    Denon 3808ci
    RTi A5 (Fronts)
    CSi A6 (Center)
    FXi 5 (Rears)
  • thsmith
    Def go with the bigger center then.
  • Fongolio
    Fongolio Posts: 3,516
    I've got a pair of RTiA7 's and am using an older CSi40 center which has a very similar voice to the A6 center. It blends perfectly with the A7's. If you can afford it go with the A6.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • carlyse_09
    carlyse_09 Posts: 3
    I agree with that of A6.Its really good and nice..My friend is using that but it seems to be expensive that's why i haven't have one right now.
