Lsi-25 more base
lumpy
I do not feel that I am getting enough base out of my 25's when listening to SACD stereo discs. They are wired with the subwoofer cable in and the speaker cables connected to the top posts with the jumpers off.
Can I - keep the subwoofer cable in, put the jumpers back, set the crossover to 80 with the dial on the back of the speakers, and then set the crossover in the reciever at 90 for all other formats.
cambridge audio DVD89 multiformat player
yamaha rxv661
3 audiosource amp 300's - driving mains (25's) and surrounds (7's and 9's)
1 audiosource amp 200 - driving center (LsiC)
yamaha rxv661
pop
media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
Post edited by lumpy on
Do not have both the a subwoofer cable plugged into the LSi25 AND the jumpers in place.
If you want to put the jumpers back in- this is what you should do: Set the front speakers on your receiver to "large" and the subwoofer setting to "off". Then adjust the subwoofer level and crossover frequency with the knobs on the back of the speakers.-Eric
-Polk Audio -
If I use the jumpers and disconect the sub cable - would I also need to unplug the speakerpop
living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma -
Disconnect the jumpers, and run the sub from the AVR to the input of the 25's.
Ben -
What exactly are you expecting out of the Lsi25's ?? Connect the jumpers, disconnect the subwoofer cables, leave the speakers plugged in, set "both" knobs on the LSi's amp at 12 o'clock position and set the speakers to "large" on your receiver. This is the settings that was recommended to me by Polk. You may also adjust the phase switch to either in phase or out of phase on the speakers amp to see which provides better bass for you. Once you start turning the gain knob past 12 o'clock you will be adding muddiness to the sound if set to high. If all else fails and you still are not happy with the bass output, then buy a subwoofer. I have a pair of these. They have a nice low fill, but they will not rattle your bean.
