Recommendations
starship2000
starship2000 Posts: 9
edited December 2008 in Speakers
So I have this equipment from my grandfather. Very nice stuff, just need to know what you think is the best settings to use.
Mains- Polk SRS 3.1TL -3db 32hz-25khz
Center- Polk CS350-LS -3db 60hz-25khz
Sides- Polk LS f/x -3db 50hz-24khz
Rears- Polk RM101 -3db 130hz-20khz
Sub- Polk PSW505 -3db 28hz-125hz
Using a Pioneer VSX-74TXVi receiver and the auto calibration modes works wonders on my room, but need to know if I should leave the speakers at what it detected, and what is the recommended crossover?
Mains, Center, Sides=Large
Rear=Small
Thanks,
Ryan
polkaudio SRS3.1TL
polkaudio CS350LS
polkaudio LS f/x
Post edited by starship2000 on
  • Conradicles
    Conradicles Posts: 6,343
    Your grandfather hooked you up!
  • thsmith
    thsmith Posts: 6,082
    Thanks,
    Ryan
    Ryan, grandfather sounds like someone to know. Congrats !
    I would try setting the XO at 60hz. Your mains will go lower than your sub but they may not have the same output as the sub 20-60hz.
    If you can take the time to learn REW it will help you make better discsions such as crossover, is the sub helping at all and placement.
    Excellent system. Does the Pioneer have pre-outs ? If so you can put an external AMP on the SRSs. My last receiver was a Pioneer VSX816, my son has it now. Its a great receiver for the money and has 110wpc.
  • starship2000
    I have been playing around with REW. Got the sub out of a corner in the room and sounds a lot better. I still don't think the center, and sides should be at large they aren't true full range. I don't want the system to be boomy I just want the impact feel. Having the center and sides at large I can feel a dramatic loss of low frequency response as to having them at small. Just don't know about the mains. Just have to play with REW and see how loud the mains can reproduce what frequencies efficiently without the sub. My grandfather did have 3 90's vintage Sony ES amps that were insane wattage power. Unfortunately he sold them along with his Sony TA-E1000EsD PreAmp.
    polkaudio SRS3.1TL
    polkaudio CS350LS
    polkaudio LS f/x
  • thsmith
    Those speakers like power. You definetly want them large. I do not run my PB13 Ultra for music. the SDA-1Cs I have do just fine.
