Center Channel Choice to Match SDA-2B
Conradicles
Conradicles Posts: 6,343
edited December 2008 in Speakers
1st of all, thanks to all who have helped me in my short time here at Club Polk.
Here is the deal:
My new TV stand only gives me 18.125" of width to put a center channel speaker. Plenty of depth and height.
Here are my current idea's:
1. CS1
2. CS245i
3. Make my own DIY center with Monitor 10 parts (internal volume would only be ~1.6 cubic feet). I could get a RD0194-1 tweet from Polk and use (2) 6.5" drivers, 10" passive and Monitor 10 XO.
4. Take this stand back to Circuit City and exchange it for a different one (but I like this one the best).
See pics below. The glass shelf can be adjusted or removed (giving me lots of room for a DIY center).
Now I need more good advice and input from those of you here who can help!
Post edited by Conradicles on
  • thsmith
    thsmith Posts: 6,082
    To bad you can't fit a CSi5 or CSiA6 but you can't. I would think the CS245i would be a better match than CS1.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Csi3 or csi a4 are smaller centers that might work. What about putting the tv on the wall and use the top of the cabinet for the center.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    leroyjr1 wrote: »
    The CSi3 is 20" wide - so it looks like that is a no go.
    The OP could try the 'phantom center' - seems like there are divided camps on whether a center is *required* in a properly designed HT setup and other folks have said they've gotten good results running a phantom center.
    Just stirring the pot....;)
  • Early B.
    Early B. Posts: 7,900
    Remove the glass shelf and build a form-fitted rectangular center channel or use a set of bookshelf speakers. The other option is to set your TV on top of the center channel. Guess who does that?;)
    "God grooves with tubes."
  • Conradicles
    Early B. wrote: »
    Use a set of bookshelf speakers...interesting. Looks like 2 of the Monitor 4A will fit in there perfect side by side. The tweeter in the 4A looks...not so good. Wonder if they would timbre match my SDA's? Probably not?
  • Conradicles
    leroyjr1 wrote: »
    Can't put it on the wall. If I could, I would have got a CSiA6 the other day when Polk was selling them dirt cheap!
    Good suggestion though.
  • Conradicles
    Erik Tracy wrote: »
    Phantom did sound good with the SDA's...but I love a good center. So much of the dialog comes from there.
  • Conradicles
    I see now that the CS250-S will fit as well.
    Anybody heard that one?
  • leroyjr1
    Might be D.I.Y. time.
  • seeclear
    seeclear Posts: 1,244
    CS245i !!!!!!!!!!!!!!!!!:D:D:D:D:D:D:D:D:D:D
    Here you go: http://www.polkaudio.com/forums/showthread.php?t=75452
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • mmadden28
    mmadden28 Posts: 4,283
    What about the center on top of the TV on a shelf?
    ____________________
    Pool: Atrium 60's/45's
  • Conradicles
    mmadden28 wrote: »
    I thought about that, but my wife hates that idea. :(
  • leroyjr1
    First buy her something nice then mount the center above the tv. :)
  • Erik Tracy
    Early B. wrote: »
    I'd second this given all the constraints you have to deal with and the 'must have' for a center.
    Maybe you could find a 'hutch/cubby' to put on top of your entertainment center that the center speaker could fit into - and be strong enough to set your TV on top of.
    It may raise up your TV by 10" - but it may have a better chance at the WAF. :D
    Good luck!
  • Conradicles
    Erik Tracy wrote: »
    Good luck!
    Thanks! That is a great idea! ;)
  • Early B.
    Just build the "cubby." It'll take 10 minutes to build and 10 minutes to paint. You only need 3 rectangular pieces of MDF and glue them into a U-shape to fit the center channel you plan to purchase.
  • Conradicles
    Still leaning to building my own DIY center. Just seems like something fun to do.
    Do you guy all agree 3/4" MDF is the way to go? I do not mind spending extra to get better wood...something I could paint and it would look good.
    What kind of wood would you use?
  • mmadden28
    Early B. wrote: »
    ...It'll take 10 minutes to build and 10 minutes to paint....
    And a couple hours in Home Depot ;)
  • Conradicles
    Thanks to all for the input. A decision has been made:
    Taking back my stand to CC and exchanging for one that is $106 cheaper and has much more room for my center.
    Then, Lord willing I'll get one of those CSiA4's from Polk for $99! Polk has some killer deals lately at their e-bay store! Good job Polk!
  • leroyjr1
    Conradicles, How high is that Tv stand? Looking for a new one and that one might fit the bill.
  • Conradicles
    I think it is ~ 22".
    Now I am thinking about keeping it and going 2.0 with no center.
    Hard to make up my mind sometimes...LOL
  • Conradicles
    CC is selling that one for $299 and it is very nice quality. Fully assembled is a big plus as well.
    You can check out all the specs at their website.
    It also has some cool LED lights inside to light up you gear.
  • ben62670
    ben62670 Posts: 15,969
    MDF is the only way to go.
    Ben
  • Chitown_Badger
    Chitown_Badger Posts: 66
    I've got my center channel in front of the tv. I used to have a CSR, and could see the tv just fine. Now I have a CSi A4 and it's actually much better viewing because of the curved cabinet.
    though I'm guessing the wife wants the center channel IN the cabinet, not on it.
    Fronts: Polk RTi10
    Center: Polk CSi A4
    Surround: Polk FXi3
    Sub: Dayton 100
    AVR: Pioneer VSX-1018AH
  • ben62670
    Why not swing down. I have all the parts except the tweeter, and wood. Polkies are more than welcome to drop in, and crash here.
    Ben
    Ben
  • Conradicles
    Sounds like a good idea...I have to pick up my new SDA's (maybe tomorrow) that are probably very close to your crib.
  • ben62670
    PM sent
    Ben
  • dudeinaroom
    dudeinaroom Posts: 3,609
    Erik Tracy wrote: »
    I ran my HT with a phantom center (SDA 2A's) And my center image was glued to the tv, if you sat in the sweet spot about a foot out of it and the center was gone. Good luck with the project, let us know how all turns out.
  • Conradicles
    Nope. Changed my mind again. My stand is too sweet to take back. It has plenty of room for a future power amp for my SDA's and my kids think it is cool with the LED lights.
    Back to a DIY center speaker. Thanks to all.;)
  • tx_polkhead
    tx_polkhead Posts: 248
    That's great news, make sure you document the process and post with pictures. I want to see this DIY CC. I am using a Monitor 7 on it's side as a CC and it sounds good with RTA 12c's as my mains but I bet a Monitor 10 would sound even better. keep us informed as you work this out.
    Abel
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
