Bi-amp rti a9
Pinktulip7
I am planning to Bi-Amp RTI A9 with carver M 4.0T(Mid & High) And Carver M 1.5T(Low),whats the best way to do that?Or should I do that at all?
TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
Post edited by Pinktulip7 on
I wouldn't bi-amp using two different amps with different power rating. It might make the speaker too unbalanced
I'd be more worried about the input gain instead of max power rating of the amp. If the gain is not exactly the same then you'll wind up with a really bright or really dull sounding speaker.
As for the power output, the tweeter/mids handles much less power than the bass section so you can use a smaller amp- just make sure the gains are the same.-Eric
-Polk Audio -
Thx for response...I will give it a try anyway to see if any gain and if I don't like it:mad:I will let one of them go for sure........:(I'd be more worried about the input gain instead of max power rating of the amp. If the gain is not exactly the same then you'll wind up with a really bright or really dull sounding speaker.
As for the power output, the tweeter/mids handles much less power than the bass section so you can use a smaller amp- just make sure the gains are the same.TV :>Panasonic TC-P55VT50
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
Just got Carver M 1.5T...It has very tight punchy deep Bass(Clean)where M 4.0T is little soft in Bass but very warm in Mid and High..TV :>Panasonic TC-P55VT50
