Mackie FR M-2006 to power LSi15s?
Anyone heard of this amp? From the specs, it'd be more than adequate to power the LSi's. Is there anything I should know before I buy? Need your opinions! Thanks.
The Mackie FR Series M-2600 features:
* 2600 Watts
* 5-Year Warranty
* Superior T-Design Cooling for Increased Reliability
* Able to Run All Night Into 2 Ohm Loads
* 5-Way Binding Posts and Speakon( Output Connectors
* True 24 dB/Oct Linkwitz/Riley Sub Woofer Crossover with 3 Selectable Frequencies
* Variable Low-Cut Filters
* XLR Outputs Switched for Daisy Chaining, and Crossover Low and High Outputs
* 2600W @ 4 ohms bridged
* 1700W @ 8 ohms bridged
* 1300W + 1300W @ 2 ohms stereo
* 850W + 850W @ 4 ohms stereo
* 500W + 500W @ 8 ohms stereo
* 2600 Watts
* 5-Year Warranty
Onkyo 805, RtiA5s, Csi5, Rti6s
Post edited by gtu2004 on
I wouldn't suggest using a pro audio amp with the LSi line, or in the home in general unless it's for a sub.
You can use PA amps to drive home gear, a few considerations though:
1) Fan noise- Some PA amps have noisy fans and transformers which will be unacceptable in a quiet home environment.
2) Inputs made for "+4" dB - they're usually balanced and sometimes do not mate up too well to consumer gear. Some PA gear I've used hummed and buzzed being fed an unbalanced signal from a consumer piece. Others did just fine.
3) Gain controls sometimes are imprecise, at least for audiophile standards. You can turn them all the way up or try to voltage match them with a 'scope or specialized volt meter.-Eric
-Polk Audio -
oh ok. thanks a lot for your advices guys. looks like trouble waiting to happen. guess i'm gonna skip this.Onkyo 805, RtiA5s, Csi5, Rti6s
the fr' m s are meant to have very poor build standards. i could have the wrong model but i spoke to someone at "dolphin music" they said lots of the new Mackie gear comes back dead. Apparently they’re churning them out so quick things are not been done properly.
I think Mackie stopped making them for a couple of months and reviewed what was going wrong. Looks like their address to their unreliability it this new 5year warranty??
And its not 4v its 1.4v usually but it varies. I would say this is irrelevant as I monitored the output of my cd player to find its well above 1v. the max was 2v.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se .
