LS90 Tweeters
timlitton
timlitton Posts: 289
edited October 2009 in Vintage Speakers
Since I joined the forums I've had the opportunity to check out pics of other LS90's. I've noticed something that's made me uneasy.
Did the LS90's only come with silver tweeters? Because mine are black. :eek:
Slowly emerging from the 90's
Fronts: Polk LSi15's
Center: Polk CS350ls
Pre: Sony STRDA555ES
Amp: Rotel RMB-1075
Sub: Velodyne SPL-1000
TV: 46" Sharp Aquos LCD
Dust magnet: Sony PS3
  • NotaSuv
    NotaSuv Posts: 3,871
    edited December 2008
    Are the domes silver? The ones in my LS 50's are a silver/black the ones on my LS 90's have a silver dome..the 350 is black/silver....all the exact same tweeter...maybe darken with age?
  • timlitton
    well, it doesn't appear that way. They are a uniform black. Dome and all. I'll post pictures later.
    Amp: Rotel RMB-1075
  • timlitton
    This isn't a picture of them but this is what they look like. The picture is of a cs250 so I'm assuming since I bought them used, the original tweeters were replaced with this type.
    Amp: Rotel RMB-1075
  • wallstreet
    wallstreet Posts: 1,405
    timlitton wrote: »
    Mine are silver. That goes for the cs-350 and fx-1000's too.
  • Herfnwolf
    Herfnwolf Posts: 52
    Wallstreet,
    Your picture shows the same tweeters that are on my LS90s and CS350.
    DJ
    original Monitor 10Bs
    Original Rosewood LS90s,
    SDA 3.1TL,
    LS/FX
    CS350
    NHT 2 x SW3P/SA-3
    B&K Ref 30,ST125.2,AV5000
    [/FONT]
  • 55LS70
    55LS70 Posts: 184
    Wallstreet's photo depicts the same tweeter utilized in the LS70's I originally purchased in 1995. I believe the part number is SL6000 and there is a sticker on the tweeter magnet stating this. I found this out due to recently replacing them with some SL6001's. The SL6001's differ from the SL6000's with a donut shape magnet (or cast metal dampner?) glued to the back of them. Otherwise they appear to be identical. It was suggested to remove the extra chuck of metal when I installed them, but due to my laziness I didn't and they sound great. A considerable improvement over the worn out SL6000's. Both had silver domes.
    On another note I worked in manufacturing for several decades and it wouldn't surprise me if your LS90's were originally equipped with those black dome tweeters. Whether they belong there or not, if they sound alright to you I would not hesitate to enjoy listening to them. Regards.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
  • DollarDave
    DollarDave Posts: 2,575
    If I am not mistaken, the 6001 has the "bucking" magnet that acts to video shield the tweeter. They aren't supposed to have an impact on the sound.
  • indosurf
    indosurf Posts: 6
    edited October 2009
    Is there a difference between the sl6001 and the sl 6502, other than the mounting method? Thanks
