digital amplifier?
trinidesignz
I got Denon 3808ci, Velodyne DPS-12 and purchasing RTi A5/A7 . Do think I need to purchase a digital amplifier.?
Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Velodyne DPS-12 (Sub)
EMOTIVA XPA-5 :cool::p;):)
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Post edited by trinidesignz on
sorry just realize I posted in the wrong area.Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
EMOTIVA XPA-5 :cool::p;):) -
trinidesignz wrote: »Do think I need to purchase a digital amplifier.?
No.
Why would you think that?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Oh I say Electronics title says Tv's • Dvd's •Amps so I thought it was there I was suppose to post. Well disney what do you think, should I get an amp to give the speakers more power or do you think my receiver should be able to give them enough JUICE.Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
The receiver should be able to drive A5 & A7 ok with no major problems, but I think you understand an amp would bring out the best in them. Was there something you felt it was missing?
FYI there's Digital amps yes, but most are not digital but Analog. Which isn't bad since we only hear analog sounds.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
ohhhh!! Thanks disney. What's a good amp you would recommend.Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
I assume that you are referring to Class D and not actually "digital". The "D" is simply the next letter designation (ie Class A, Class A/B, Class C, etc.). I had found a real nice write-up on Class-D amplifiers that was put out by Rotel Global Press. The Class D amp actually works on Pulse Width Modulation (PWM). While PWM can be purely digital it is also an analog technique. These amps sound like cutting edge technology and the best thing since the transistor with their > 90% efficiency and they can be very good. They show up in many portable devices as well as high end audio. They can sound really good if they are carefully designed but can also sound like crap if the design is skimpy.
Back to your question...
Denon receivers are no slackers and are able to drive 4 ohm speakers without trouble. The 3808 has an spec output of 130W into each channel at 8 ohms. This should do fine. I am drooling!Stan
Main 2ch:
HT:
Other stuff:
trinidesignz wrote: »I got Denon 3808ci, Velodyne DPS-12 and purchasing RTi A5/A7 . Do think I need to purchase a digital amplifier.?
Before I got my Sunfire TGA5400 I was driving 4 LSi15, and an LSiC with the Sony DA7100ES digital amp. Worked great. Before I got the Sony I was using a Denon 3805. Worked great. Before I got the Denon I was using a Sony DA5000ES digital amp. Worked great.
Now I have all this extra equipment sitting in the garage waiting to be used in an emergency.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
trinidesignz wrote: »ohhhh!! Thanks disney. What's a good amp you would recommend.
It's more on what you wish too spend and if used is ok. www.Audiogon.com is a good place for used or this forum as members here offer sweet deals at times. If new to this give it some time, the audio bug will bit you I'm sure you will spend some $$ in time.
BTW very good points from Skrol, amps are built in classes of design. The D class is newer more efficient but can be a bit noisier. I believe why filter out the noise, if not done that way in the beginning. I like AB / B class amps just my $.02 here.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
If you are just going to run a 5.1 system, I would Bi-Amp the RTia5/7's from the 3808 and call it a day.
Some people love Class "D" amplification and others do not. Personally I am an old school Class "A" guy.
Thanks alot fellas. Now I just have to wait on polkdirect to put some rti a7 on sale.:DSamsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
