In Wall Center
nrg
nrg Posts: 3
edited December 2008 in Speakers
Working around fireplace for center channel and need adv.
Have Flatscreen mounted about 1 ft above fireplace ... and can either work above or below tv for center channel.
Have somewhat decided on Monitor 70's front for front and M10's or 30's for surround in 5.1 system. Wanted CS2...esp. at such at a bargain price (under $100) but now realize its not made for wall mount.
Can anyone suggest an in wall center ..or alt. plan that gives me a strong center ...at hopefully under $200 ...that obviously matches up with the Monitors.
Post edited by nrg on
  • curved
    curved Posts: 664
    Going to need more details about the fireplace.....is it brick? Drywall? Gas, Wood? Is there a mantle?
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • nrg
    nrg Posts: 3
    Fireplace is self-contained gas with glass coverage...no mantle and seldom if ever used since its the plug and play variety that comes with new construction.
    This particular wall has plenty of depth behind it if I do end up having to go with an in wall Center channel.
    thanks for response..anxious to get your feedback.
  • curved
    curved Posts: 664
    Personally I would stick with the CS2 as it's voice matched, etc. However, I would double check with Eric Wong (Polk CS) about in-wall applications.
    Others can chime in regarding a mounting bracket that would hold the CS2 no problem.
    Pre - Nak CA-5
    BR - LG BD390
  • okiepolkie
    okiepolkie Posts: 2,258
    An in-wall center would fine, or you could build a cavity above/below the television and mount the CS2 in the hole. Or something like this would work underneath the tv: http://www.jr.com/bt15-center-channel-speaker-bracket/pe/BTH_BT15_hy_BK/
    Tschüss
    Zach
  • Eric W
    Eric W Posts: 556
    okiepolkie wrote: »
    I really wouldn't recommend burying a speaker made to be freestanding in the wall. Especially with the rear firing port.
    We recommend that center mount frequently, it can support up to 33 lbs.
    The best matching in-wall center would be a single RC65i or SC65.
    -Eric
    -Polk Audio
  • nrg
    nrg Posts: 3
    noted...as a newbie I appreciate all the advice. While I'm on a roll ..and working on my theater degree let me ask another opinion.
    2 days ago I was set on Monitor 70s, CS2, and M10's or 30's for surround.
    But now for just a couple of hundred $ more I'm considering RTi8's; RTi'4 for surround or FXi3's (if I can find); and either CSi 3 or 5.
    Is the difference substantial? I'm going to have to stop reading these posts or I'll be in the L series by Saturday.
  • okiepolkie
    Eric Wong wrote: »
    I didn't even look to see that the CS2 is rear firing. In that case, I would go with the brackets as well.
    nrg wrote: »
    I would go with the RT series and enjoy the better overall sound. Like you said, its not much more money....
    Tschüss
    Zach
