PSW505 port noise
tytus45
tytus45 Posts: 14
Looking for some ideas. Just picked up a psw505 and noticed that at higher volumes and/or lower bass (30 or below) seems to be a fair amount of port noise...i was thinking of adding some baffling to the box itself. Another idea was to seal the box itself,but dont know if that will doom the subwoofer..looking for ideas...
Post edited by tytus45 on
  • Dean_KS
    Dean_KS Posts: 6
    edited December 2008
    If the ports were rear-firing, you would hear less flow turbulence.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Polk created the slot port to help reduce port noise. It's always going to exist when playing at loud levels. I wouldn't seal it up but should look into sealed subs. Also I don't think that sub will hit below 30 hz
  • curved
    curved Posts: 664
    Put a sock in it.....literally:D
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • tytus45
    tytus45 Posts: 14
    Will sealing off the port of a sub that is designed to be ported damage the sub itself?
  • ShinAce
    ShinAce Posts: 1,194
    No damage.
    Another option is to use a $%^$ load of straws. You would fill the slot with straws until it's fairly tight. By breaking up the one big slot into a bunch of tiny slots, it will help with turbulent flow. It won't fix the problem, but it helps.
