What speakers next?
jack200k
jack200k Posts: 2
edited December 2008 in Speakers
Hi all,
First post....
Currently I have RTI8s with a psw505 sub hooked to each for my main speakers and really like the way they sound. I listen to a lot of 2 channel as well they get a lot of HT use. I was planning on moving them to the back of my HT and replacing them. After some digging around I found that the RTI10s are not very good for 2 channel listening. So I figured I would go with RTI12s.
Currently I have a Panasonic SA-XR55 reciever. Which puts out 100 watts per channel. I have heard the 12s need far more power than the 8s. Is this enough power for the 12s or am I looking at getting an amp?
My other option is to just get another set of 8s. I am on a budget so that is why I am going with the RTI series as I can get them on clearance at different outlets.
I am also considering the Axiom M60 v2. I can source them locally as I am in Ontario, Canada.
Post edited by jack200k on
