CSi5 (or A6) crossover frequency?
prstrings
prstrings Posts: 33
edited December 2008 in Speakers
I currently have CSi5 set at 40hz (per the recommendation of someone on this board), but the Audyssey set it at full band.
Does anyone have any input on which is proper?
Post edited by prstrings on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    prstrings wrote: »
    Do you have a sub in your setup?
    If you do, then you may want to change the xover freq of the center to be something higher and let the sub handle the lower freqs.
  • Pinktulip7
    Pinktulip7 Posts: 249
    prstrings wrote: »
    80hz...:D
    TV :>Panasonic TC-P55VT50
    RECEIVER :> HARMAN KARDON AVR 7300
    FRONT :> L & R :> POLK RTI A9 500 W
    AMP :1> PARASOUND HALO A21 250 W
    AMP :2> EMOTIVA UPA-1 200 W
    CENTER :> POLK LSiM 706c 250 W
    SURROUND SIDE :> POLK RTi A3 150 W
    SURROUND REAR :>POLK FXI A6 150 W
    DVD PLAYER(HD) :>TOSHIBA HD X-A2
    DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
    POWER CONDITIONER :> PANAMAX M5400-EX
    SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
    SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear
  • prstrings
    prstrings Posts: 33
    Erik Tracy wrote: »
    I do not have a sub right now. I just have the towers and the center. Looking to add surrounds and a sub in the next few months.
  • Erik Tracy
    prstrings wrote: »
    Does your avr have an auto-calibration feature?
    If so, then you may want to run with whatever it sets your towers and center to - until you get a sub.
    With no sub, your options may be limited to what features you have on your avr.
    One option is to run your towers and center as 'full range' or 'large' or whatever the equivalent is for your avr.
    Another option, if your avr permits it, is to run your towers as 'full range' or 'large' and then set your center to with a crossover frequency of 80Hz as suggested.
  • prstrings
    prstrings Posts: 33
    Erik Tracy wrote: »
    I ran Audyssey, the auto-calibration on my Onkyo 805, and it set the center channel at full band, just like my towers. I thought that was kind of strange. Billbillw on here suggested setting it at 40hz, and I have done so. I'm just wondering if there are other opinions out there, and what difference it will make setting it at full band.
