How do you get away from...
I-SIG
...a straight? You gotta call, right? Even if the same guy has beaten you with a flush the previous times you've had a straight, right? That's it. just had to vent a little.
Wes
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
LOL! I remember watching 'High Stakes Poker' a couple of seasons ago, and Negraneau was getting REPEATEDLY sandbagged by flushes, 4/ kind, Full houses.
My condolences on your lossesI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Depends on who is in position and what is on the board. If there is a possible flush on the board and the guy goes all in. I would probably fold it if it meant all my chips.My Home Theater (WIP):
Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
Receiver: Denon AVR-1905
Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
Dual Subs: PSW202, and behind the couch Denon 8"
My showcase link:
Media Room pics -
Hmmm.... Welll it depends on many things LOL....a straight? You gotta call, right? Even if the same guy has beaten you with a flush the previous times you've had a straight, right? That's it. just had to vent a little.
Wes
1.What game is it? 5 card draw -7 card draw- NL Texas holdem?
2. Is it the highest possible straight?
3. How many people are in the pot? and is at least 2 people and preferably someone with more chips than the guy originally going all in calling before you?
4. Is it for all your chips?
5. Does the person going all in bluff a lot? and is the other person calling before you call anything?
6. Is there 3 or 4 cards of the same suit on the table? assuming this is NL texas Holdem (4 cards of the same suit would increase the odds of more than one player having a flush)
Many factors weigh in to placing or calling a bet each situation is unique.
For example if I had the highest possible straight and 2 people bet before me and there was only 3 cards of the same suit on the table and it was 5th street and I had more chips than the original better and the second caller had more chips than the original better then I would raise the bet to double the orginal wager, the odds of both players having a flush is pretty small and even if you lost half the bet to the fellow with a flush you would break even with the re raise if the second caller of the original all in called you and you had a higher straight.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
