Parts for SDA SRS 2.3 X/O Upgrade
Dennis47
I'm thinking of obtaining a set of SDA SRA 2.3's and would want to
upgrade their crossovers. I've tried searching the forum posts for a
parts list in order to establish a cost estimate for the upgrade, but
without results. Does anyone have a list of the caps and resistors
required to accomplish this upgrade. Also, what componet brands
would you recommend?
Thanks,
Dennis
Thanks,
Dennis
PL 4000 II / PL 400 II x2 / PL 5100 II / PL 6000 II
PL 7000 II / PL 1000 w/JDV mod x2 / PL 1100 II
Carver C-1 / C-11 / C-4000t / M-1.0t (MKII opt 002)
M-1.5t x2 / TFM-15 / TFM-22 x2 / TFM-24 x2
TFM-45 x2 / HR-752 / DPL-33 / TD-1400 / TD-1700
TDR-2400 / TX-12 / DTL-100 / SDA-490t
Thorens 316 / Roberts 770X x2 / ADC SS3 MKII
Polk SDA SRS / Polk SDA SRS 2.3 (XO upgrade)
Polk SDA-2B (XO upgrade)
Polk Monitor 12 & Monitor 5jr
Polk Monitor 10B (XO upgrade)
Polk Monitor 7C (XO upgrade)
Post edited by Dennis47 on
Here you go,, compliments of the keeper of the "Krakin",, Carl knows his 2.3 crossovers,,he helped me when I did mine--good luck.
http://www.polkaudio.com/forums/showthread.php?t=35837&highlight=crossover+componentsJC approves....he told me so. (F-1 nut) -
Thanks George!PL 4000 II / PL 400 II x2 / PL 5100 II / PL 6000 II
Polk Monitor 7C (XO upgrade) -
The above link by george daniel is dead I have the same issue 2.3 (not TL's) anybody have anything? :web sight to buy : the correct oversized board the latest crossover components the Larry ring kit ETC
www.gimpod.com has the parts list and schematics you seek as well as lots of other valuable info
http://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3 Should be a link where I modded mine. If you use the aftermarket boards I think there I a jumper you need to install for the 2.3 version if I recall correctly. It's been a while.
Here is Carl's original thread with parts/quantity. He went with Jeff's (Sonicap) suggestions of by-pass all the capacitors in the tweeter circuit with a 0.1 uF cap though. The uF values for the capacitors in the tweeter circuit were thus reduced by 0.1 uF. He does show the quantities for exact value caps, no by-pass.
http://forum.polkaudio.com/discussion/35837/srs-2-3-crossover-and-tweeter-upgrades
Gimpod's site rules for proper setup. Much better than working off the original Polk schematic. He covers the jumpers, parts needed. Once the board is populated with large caps it's hard to see the jumpers.
I did Carl's 2.3 Gimpod board xovers. Here is a link to my photobucket page with more pics.
http://s417.photobucket.com/user/scompracer/library/Carls 23 xover?sort=9&page=1
Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Check with @westmassguy about @gimpods boards.
