How good is the PSW1000
Lowell_M
So... How good is the PSW1000 for $400?
I guess what I am getting at is the previous generation Polk Subs are known for not performing well at their price points. So, since the PSW1000 is going for $400 on ebay, just how good is it in the $400 price range?
If you were to choose an impulse buy on the $400 PSW1000 and really piss of your wife,or putting off a purchase for a while to buy a used SVS, or maybe even a even a Polk MicroPro sub what would you do? ...a.k.a. would the PSW1000 be enough of an incremental gain in performance over the Velo CHT-12 I have now (HT and 2-channel) to justify the $400 purchase?
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
IMHO, Polk subwoofers do not go down low.... it tapers off below 35Hz pretty quickly... So if you like really low bass, you are not going to find it on a Polk. Don't know about the newer stuff tho. But for $400, the PSW1000 is a sweet deal but I don't think it will better your Velodyne 12" sub... you really need to spend over $1000 to get a sub with really good, low bass...
Here's a thread with the usual garbage, but the one guy who owned the PSW1000 sounded pretty honest. A fine music sub, but bottoms like a bugger during LFE blockbusters. If you're an HT guy, then save for something better.
http://forums.audioholics.com/forums/showthread.php?t=50069
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
you should also look at the epik valor. i have the caliber and they both have the same driver. Here is the site http://www.epiksubwoofers.com/Products.html. i also have velodyne vrp1200 i got for 300.00 dollars on ebay. When i got the caliber i still had to keep the velo because i love it that much.Audio:
Onkyo :tx-sr805
Polk: rti8's
Polk: rti4's
Polk: fxi3's
Polk: csi'3
Velodyne: VRP 1200
Epik: Caliber
Video:
Panasonic:TH-42PX60U 42"Plasma
Power Conditioner:
Monster Power: HTS 3600 MKII Home Theater
Dvd:
Sony: BDP-350
Game Systems
WII
PS3 -
Hmmm... Thanks Ron. This would be for 75% HT...and I play movies loud. I'd probably destroy the sub. My velo hits hard down to 20ish, although with plenty of port noise and sloppyness. I've never bottomed it out though.
I'll stick with what I've got for now. Would love try to integrate a PSW1000 into my 2-channel system upstairs for the hell of it, but that ADCOM has so much slam I don't think I need it.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
If only I lived in Miami.....HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
