Need help to setup the NAD T755
mauitang
mauitang Posts: 12
edited December 2008 in Electronics
i just got the T755, but i wonder where is the setting for the lsi 9 Nominal Impedance 4 ohms
thank u so much.....
Post edited by mauitang on
  • pearsall001
    pearsall001 Posts: 5,327
    mauitang wrote: »
    I have the T773 & there isn't any switch for different speaker loads. I believe your T755 is set up the same way. The NAD's are just so robust that they handle anything you throw at them without having to set any kind of a load switch. Just hook 'em up & enjoy!
