Rti-12 temporary hookup
I have a set of rti-12 and currently have two independent amps powering these. I am selling the amps and going to buy a new two channel amp but will temporarily power the upper portion of the towers with my receiver. Is this a good idea or should I just put the jumper on and use bought top and bottom. They will be powered by a pioneer sc-05
Post edited by Montoya on
Depends, does the amp have gain control? If not you could wind up with a very bright or very dull sounding speaker.
If it's just temporary I'd say put the jumpers back in.-Eric
-Polk Audio -
+1 for the jumpers - with no gain control, that's most likely going to happen (too dull or bright).....although you may get lucky
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors**
