polk RTI A7's or A9's
graco1
graco1 Posts: 8
edited December 2008 in Speakers
i went to a dealer who have both of them the a7's and a9's i listen to them both thinking that the the a9's will sound similar to the a7's just a heavier bottom, to my amazement the 7's sounded a bit not open and clearer as the 9's is there different crossovers in them? i love how the 9's when played when listening at low low volume, i would love the 7's because the 9's are very HUGE is there any adjustments can be done on the 7's to make it sound the same way as the 9's i already have a outlaws top of the line sub so i dont need the bass, or is there a bookshelve model that will do the same justice if i just add the subwoofer, ps i dont want to go back at the store again to demo they may think im crazy spent like 20-30 mins listening i know the guy salesman thought i was gonna purchase right there and THEN
Post edited by graco1 on
  • curved
    curved Posts: 664
    The LSi9's or the LSi15's - check them out under the products section above.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • Fongolio
    Fongolio Posts: 3,516
    I have a pair of A7's and they open up a little more as they break in. At one year old now they sound fantastic. Because the A9's have 3 bass drivers and 2 mid drivers they will definatley sound fuller on the bottom and slightly better mids. However I have absolutely no complaints about the A7's. They have exceeded all expectations. The bass goes way down deep but is very articulate (controlled not boomy). If your listening room is large and you have a high power amp/receiver go for the A9's. In a smaller room the A7's will do great. Both benefit from clean high current wattage. The A7's sound really good on my Pioneer Elite AVR (110 wpc) but they sound phenomonal on my two channel Carver amp (225 wpc). Oh and who cares what the salesman thinks, you are laying out a lot of cash. Demo until you are happy with your decision is my opinion.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • mmadden28
    mmadden28 Posts: 4,283
    Fongolio wrote: »
    ...Oh and who cares what the salesman thinks, you are laying out a lot of cash. Demo until you are happy with your decision is my opinion.
    Ditto ^^^^
    ____________________
    Pool: Atrium 60's/45's
  • leroyjr1
    leroyjr1 Posts: 8,785
    The 1 mid driver in the RTI A7 is the difference . I had both in house and thought the mids on the 7's were under par. The one driver in the 7's don't open up until higher volumes. Also the bright tweeter over powered the one mid driver in the 7's. I ended up going with the A5's and a9's. I would go with the 9's if I were you, all around better speaker.
    Don't over look the A5's either. With a sub sounds great.
  • leroyjr1
    graco1 wrote: »
    Check out POLK DIRECT EBAY STORE
    RTI A5 = $379.99
    RTI A7 = $499.99
    RTI A9 = 899.99
    All are plus shipping.
