yamaha left channel dead
steelervic
steelervic Posts: 142
edited December 2008 in Electronics
i just got a good deal on a yamaha a1000 integrated amp, until i got it home and the left channel doesn't work. fuses look good, any ideas as to what my problem may be?
thanks
Post edited by steelervic on
  • ntculenuff
    ntculenuff Posts: 1,146
    you could buy this one, the right channel is out;)
    hahaha i'm only playin
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
    mhardy6647 Posts: 35,232
    It's a pretty nice amplifier; probably worth repair (or at least troubleshooting).
    Could be dirty pots (controls) and/or switches. Try fiddling a bit; jiggle buttons/knobs/toggles. Things like tape monitors and mute switches are often culprits, as are function selectors (which are pushbuttons on the A-1000 IIRC).
    As I recall, the A-1000 has separate pre in/main out; probably has a switch on the back panel rather than jumpers. Check.
    HTH.
    If you are inclined to join Audiokarma, there's a Yamaha expert there, Merrylander. He's not actively seeking work, but he's a great fellow and will generally kindly and patiently dispense advice. Even if you don't wish to join, you can go and search for threads on that amp; maybe find some useful info.
    That is not a model I have any personal experience with, unfortunately.
    EDIT: Having Googled a bit, I am now wondering whether your amp is a DSP A-1000? If so... you can disregard pretty much everything I said above; I know nothing about that amp. Sorry :-(
    This might be of interest... is this the amp in question?
    http://www.audiokarma.org/forums/showthread.php?t=196415
  • steelervic
    yes, thats it.
