Speakers for a Steam Shower
tghodge
tghodge Posts: 15
edited March 2009 in Speakers
I have another thread for my HT, but I figured these were two very different topics. As part of our attic renovation and theater build we are also adding a bedroom and full bath. In the bath we are doing a steam shower. I use Sonos for whole home audio and would and have an extra ZP100 that would power a set of speakers...question is, what speakers do I get? I was wondering about marine speakers that Polk makes for boating. They need to be vapor proof and pretty much splash proof. They are not for critical listening, but would like them to sound decent. Any ideas? The cavity in the wall will probably only accomodate a pair od 6.5s...maybe could get some 8 inch, but it would be tight between the joists. Any recommendations?
Post edited by tghodge on
  • Eric W
    Eric W Posts: 556
    edited December 2008
    If you're limited by about 6.5" OD You may want to consider the MM651UM Ultra Marine speakers. They sound great, don't have a 2 piece external crossover to deal with. Just keep in mind they're 4 ohm.
    http://www.polkaudio.com/caraudio/products/6-1-2/speakers/mm651um/
    -Eric
    -Polk Audio
  • tghodge
    tghodge Posts: 15
    Eric Wong wrote: »
    Thanks Eric. Would these mount similar to an in celing speaker? I would have to cut the hole in the cement board and then once I am done tiling the shower put them in with a bead of silicone to keep the steam from going behind the wall into the celing joists (that would be extremly bad). Wasnt sure how marine speakers mounted and if they had the clips or not. These would be in the celing with their weight wanting to force them down, so wasnt sure about their mounting ability.
  • Upstatemax
    Upstatemax Posts: 2,735
    Who is installing the Steam Shower?
    They might have some ideas for you... Have you talked to your contractor about the exact cost of a Steam Shower?
  • Eric W
    Eric W Posts: 556
    No, the MM651UM do not have the "dog ears" like an in ceiling speaker does. You would screw it in.
    You can use any of our current in ceiling speakers (except the LC80i-IP, cause it has electronics behind it) in a moist environment such as a steam shower, but the smallest one we have is the SC50 which is 7.5" in diameter. It has stainless hardware, rubber surrounds and a powdercoated aluminum grille.
    http://www.polkaudio.com/homeaudio/products/inceiling/hidden/sc50/
    -Eric
    -Polk Audio
  • tghodge
    tghodge Posts: 15
    I am doing most of the work myself although will bring in a tile guy for the cement board, mud pan, etc. I already have the steam generator and completed the rough in for the plumbing. A steam shower is not much more expensive than a traditional shower with the exception of the generator, more tile, etc. My brother is in the plumbing business so got all the shower valves, generator, etc at cost, so that saves a ton. I do have a buddy that has some Mr. Steam speakers (not sure who manufactures them for Mr. Steam) and they sound pretty bad. Again its not for critical listening, but would at least like a little clarity. I posted also on the Sonos forum to see if there were any recommendations there.
  • Upstatemax
    Did you look up how much the cement is for a steam shower?
    It's VERY expensive.
    My Father used to remodel homes and HIS cost as a contractor was nearly $1,000 for the cement... It's not the same cement as a standard shower.
  • tghodge
    tghodge Posts: 15
    Upstatemax wrote: »
    From my resarch and the couple of freinds that already have steam showers I plan on doing concrete board which is the backer board and then tile over it with a porcelain tile Are you talking about poured concrete? Not sure they still do resedential steam showers that way. To your point I will talk to a few different subs to understand their methodolgy on construction. The shower may have to hold off and I just build out the home theater instead!!
  • tghodge
    tghodge Posts: 15
    Eric Wong wrote: »
    Eric this is good to know. I have RC80i's as my in celing for my office, kitchen, bedrooms, etc. If I can use the current in line I can figure out what i can fit inbetween the joists. I assume I would install the exact same way, just do some clear silicone where the speakers meet the porcelain tile.
  • Upstatemax
    tghodge wrote: »
    I was talking about the cement/mortor for the tile... IIRC, it's an ultra-fine cement mix.
  • tghodge
    tghodge Posts: 15
    Upstatemax wrote: »
    understood now. I will make sure in my conversations to ask specifics on what they are using. I assume becuase of the higher humidty this type will hold up better and stronger than the normal mortar? Thanks for the heads up. I will add it to my items to discuss with the tile folks. Much appreciated.
  • tghodge
    tghodge Posts: 15
    Eric Wong wrote: »
    Eric: Would the RC60i also fit the moist environment criteria? I understand the SC line does but was also curious if the RCi line did as well. I think I can fit a pair of RC60i's, but they do not state the specific stainless, powdercoated verbiage that is under the SC line.
  • dorokusai
    dorokusai Posts: 25,576
    What about the Kohler/Polk Audio speaker?
  • Eric W
    Eric W Posts: 556
    tghodge wrote: »
    The round RCi's do come with aluminum grilles and stainless mounting hardware.
    The RCi series does not hold up to temperature or moisture extremes like the other in-walls (like SC, TCi and LCi). I just spoke with the QA department and they recommend no more than 160° F for an RCi.
    How hot do you expect to run the steam shower?
    dorokusai wrote: »
    That's an excellent suggestion. Though the "speaker" is rectangular, if that's OK with the OP.
    http://www.us.kohler.com/onlinecatalog/detail.jsp?item=12811402
    It will survive both the water and the heat.
    -Eric
    -Polk Audio
  • Willow
    Willow Posts: 11,222
    dorokusai wrote: »
    That's was my suggestion, not that we use them, I just remember an article about them.
  • trash2005
    trash2005 Posts: 2
    edited March 2009
    Hi, I have TCi 610i speakers installed throughout my new house including the steam shower. The installer swore that they were fine for the steam shower... however after only a couple uses of the steam shower the grills appear to have a brown residue (although it wipes off easily). I am concerned that these are not proper speakers for the environment. Can anyone comment?
    Thanks for the help.
  • BlueFox
    BlueFox Posts: 15,251
    edited March 2009
    tghodge wrote: »
    First, what is a steam shower? Second, is this like a sauna or spa where you stay in it for 30-60 minutes? I don't have any idea what speakers would work, but I am going to remodel a bathroom.
  • dorokusai
    edited March 2009
    trash2005 wrote: »
    They are NOT the correct speakers for that type of installation.
  • trash2005
    trash2005 Posts: 2
    edited March 2009
    Okay, If the TCi610i are not the correct speakers... which Polk or other manufacturer speakers are of similar size that can be used in a steam shower.
    Thanks.
  • dorokusai
    edited March 2009
    Or could just stay here, on the homepage and see what's available.....
    http://www.polkaudio.com/caraudio/index.php
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    edited March 2009
    Why waste polk speakers? use BOSE
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • dorokusai
    edited March 2009
    Lasareath wrote: »
    But, Since you can't buy the MM651UM's Here then you might as well go back to Crutchfield and buy them there.
    Sure you can Genius McGee....call 866.764.1801 between 9-1030 EST.
