Surround Sound System
theunknown
Hell Experts
I have have LSi7 for karaoke purpose and now I am interested in setting up a 7.1 Movie Theather. What would it be a good setup for this purpose? What type of Center/Surround Sound speakers would I need? Please help
Thanks in advance!!
Thanks in advance!!
Post edited by theunknown on
There are many configurations that can be used with the LSi7's. Dependent on room size, and even if you have room or need for a 7.1 system?
Could use the 7's as mains, surrounds, or rear back surrounds in 7.1. Could get all LSi7's and use an LSiC as your center, there are many different options, I'd definetly stick with all LSi series to stay matched. BTW, make sure you grab a healthy 4 ohm stable amp to properly power all of them. -
Hi Mike
Thanks for your prompt response. My family room is small that's why I have to go with the LSI7 for main. I am looking for something small but have good sound. LSIC and LSI FX are in my wishlist now. Is it really worth that much for a lsiC?
I dont know much about amps. The one I have is an Onkyo 606B which sounds fine with my LSI7. Is that amp capable of handling the speakers i listed above or should I go for something lower? -
I would absolutely stick with the LSiC. For rears, either dipole/bipole or another LSi7 would work just fine.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Welcome to Club Polk. Having a full line up of all LSI's would put a strain on your receiver and probably put it into protect mode. What's more, you don't have preout inputs to attach a separate amplifier.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Oh gosh.. Thanks for the welcoming. Does it mean my Onkyo 606 is not able to handle these lsi? *sighs..
Bluntly...Yes.
If you intend to stick with the LSI series, you will need at the very least an Onkyo 705, then you have to purchase a 5-7 channel 200wpc (minimum) amplifier to make sure that the speakers are operating to their full potential.
You can buy used from here, or from audiogon, which will save you major coin. But once it is all setup, you will have one slammin system!theunknown wrote: »Oh gosh.. Thanks for the welcoming. Does it mean my Onkyo 606 is not able to handle these lsi? *sighs..Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
arhh.. i should have waited for the 705 instead. The cost would be the same buying a 705 Plus the power conditioner. what is another solution without buying two devices? Thanks again
theunknown, in case you did not understand and your last post was not a momentary brain fade, the second device would be a power amp. not power conditioner. The other options would be a high power, high current AVR that is 4 ohm stable/capable, of which there are few. NAD, Rotel, maybe Outlaw come to mind. The other option would be a pre pro and an amp which essentially the same as an AVR with pre outs and an amp where you don't use the internal amp of the AVR and basically it becomes the pre pro.
Guys,
Would an Onkyo TX SR805 work with the setup I mentioned above?
