Speaker Connections
I was wondering what people typically use for their speaker connections?
1. Bare Wire
2. Plugs
3. Pins
4. Spades
5. Other?
I have heard different opinions about which is better, but I wanted to hear good reasons for/against any of the options.
Jason
1. Bare Wire
2. Plugs
3. Pins
4. Spades
5. Other?
Jason
Post edited by north51 on
Bare wire.
Plugs for the mains and bare wires for everything else.
Maurice -
Plugs for everything (receiver and speakers)
Denon 3802 receiver
Denon DvD 1600 progressive scan
CS240i center
RT1000 fronts
RT28i surrounds
FX300i Rear back surrounds
Velodyne CHT 10 sub
Velodyne CHT 12 sub
Mitsibishi 27" tele
Monster cables/ 10 ga speaker wire -
Plugs everywhere.My 7.1 setup consists of:
Denon 3803
Panasonic DVD
RTi70s front
CSi40 front center
RTi28s side surround
FXi30s back surround
PSW202 Subwoofer - Hey, it's my first sub!
RCA 46" 4:3 RPTV -
I like'em naked, much sexier that way.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
Im going to use Banana Plugs all around - especially on the amps - I am might make the end connected to the speakers bare...who knowsDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
Bare wire.....why would you want to add more resistance than necessary unless you move or exchange speakers frequently...
I'm with naked.......
My 2 cents Peace StuffMDYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube -
To all you naked people.
I've never seen any documented proof that banana plugs add resistance. Using good gold-plated banana plugs should not affect the sound in any perceivable way. Banana plugs offer a greater contact area than bare wire alone which should be a good thing and they help prevent shorts that naked wire can cause. The main resistance issue is speaker wire gauge. If you use good 12 or 14 gauge speaker wire instead of the more common 16 or 18 gauge wire than you have solved the main resistance issue.My 7.1 setup consists of:
Denon 3803
Panasonic DVD
RTi70s front
CSi40 front center
RCA 46" 4:3 RPTV -
I used banana plugs with 12 gauge wire and soldered all my connections.jerry
