Speaker suggestion
Hi everyone,
I have a quick question on speaker selection. I'm running a 7.1 surround system. I'm currently using a pair of RTi A1's for rear surrounds and a pair of R150's for the side surounds. I want to replace the R150's with something a bit better so I'm looking for some options.
One obvious option would be to get another pair of RTi A1's
Another thought I had was to get a pair of monitor 50's at newegg.
Anyone have any thoughts on the RTi A1's vs Monitors 50s?
Post edited by Olecranon on
Wut are you using for fronts and a center? Give us the whole setup so we can give you better advice.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Ok, here is my system:
Speakers
Center : polk CSi3
L/R Fronts : Vandersteen 2Ce Signature Series
Subwoofer : Vandersteen V2W (three 8" drivers, 300 watts)
L/R Surrounds : Polk R150 bookshelf
L/R Rear Surrounds : Polk RTi A1 bookshelf
Electronics
Rotel RSX-1056 Receiver (7.1 analog input)
Rotel RB-980BX 2 channel Amp (powers the vandersteen fronts)
Rotel RCD-950 CD Player
Panasonic BD-55 Blu Ray player (using 7.1 analog output)
Toshiba HD-A2 HD DVD Player -
Get the A1's to match....no brainerLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Go for the A1's for its sound and looks.
