WHich sub to get?
lando885
lando885 Posts: 33
edited December 2008 in Speakers
hey guys, i put this question here instead of the sub section because its not about tweaking a sub, but selection of the correct sub for my system.
I'm getting a Cambridge 740A and a pair of b&w 684's. i went to the store and tried them out, compared them to some lsi9's, and like these ones. But they are a little weak on the bass. In about a month I'm gonna go out and get a sub, but i was wondering what would be a good sub for what i want. I don't listen to rap or hip hop, i don't want an obscene vibrating box messing up the clarity and complexity of my system, which i think sounds great. But something to make it a bit fuller. The 684's have a 1'in tweeter, and a pair of 6.5'in cones. One is designated for bass, and the other is for mids and bass. It sounds good, but i want to thicken it up. Something with a fast response time and that will not over power the 684's, but enhance them. Sorry if i sound picky, lol. Anyone have an idea of what i should be looking into?
Project Debut Carbon, Ortofon 2M Red cartridge.
Cambridge Audio 740a, only using preamp section.
Parasound HCA 2200 mk2.
Dahlquist DQ10's, passive dahlquist crossover @ sub.
Post edited by lando885 on
  • SolidSqual
    SolidSqual Posts: 5,218
    Most anything by Martin Logan, Totem or REL. I've also heard the new Polk subs are a good bang for the buck.
  • leroyjr1
    leroyjr1 Posts: 8,785
    What about a B&W sub?
  • kolky
    kolky Posts: 13
    What's your budget?
    Have you checked out some of the internet direct retailers? You can usually get a lot more sub for your money.
    Some you may want to take a look at are:
    HSU
    SVS
    Elemental Designs
    Epik
    Outlaw
    AV123 (MFW-15)
    Samsung 5085
    Denon 1909
    Polk RTi A5 Fronts
    Polk CSi A4 Center
    Polk FXi A4 Surrounds
    MFW-15 Sub
    treitz3 Posts: 19,249
    To complete the spectrum of frequencies without messing with the sonic quality that you already have? I'd check out the Polk Audio DSW lineup. Polk has come a long way with their subs and they are definitely worthy of your consideration.
  • pearsall001
    pearsall001 Posts: 5,094
    Velodyne SPL or DD series. No need to look any further.
  • curved
    curved Posts: 664
    Snell, ML, Velo
    What's your budget?
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • lando885
    lando885 Posts: 33
    hey guys, thanks for the info. After thinking about it, i decided to upgrade the B&W 684's to the 683's, which are a 3-way with 2 bass drivers. This should solve the problem, as they do a really good job at reproducing those lower frequencies. my budget was going to be about $300, which was the cost of the upgrade fro the 684 to the 683's.
    cheers!
  • curved
    curved Posts: 664
    Good choice. I love the B&W 683's.
    Pre - Nak CA-5
    BR - LG BD390
