New need Help!
CLPolk
Hi All http://www.polkaudio.com/forums/showthread.php?t=75053 I have a newbie ? I Think I would like to set up a 5.1 System Using SDA-1's as fronts SDA-2's as Rears and Fx500i as 2 centers and some kind of Sub. What are your thought's Good or Bad I can take it!!
Thanks Jim
Thanks Jim
- SDA SRS 2
- SDA 1A
- Monitor 11
- Monitor 7B
- CS350lsi
- RM-6600
- FX500i
Post edited by CLPolk on
SDAs for mains will be excellent but for rears will be a waste, there was an earlier post on wanting to do this but most all recommeded against it as it is a waste.Speakers: SDA-1C (most all the goodies)
use the 1's for the ht right and left, get some monitor 7 or 10 for your surrounds, and go with a pair of 5's for the center, just watch how close you stick them to your TV, I know crt's don't like magnets, as far as the other I could not tell you.
Use the 2's in a 2ch setup
I don't know, It's just a suggestion
Later,
dude -
I don't believe the SDA's are shielded. I too thought about a setup like the one you are thinking about. Most said it would be a waste to put SDA speakers in the rear. I have to keep reminding myself these speakers were before Home Theater and are not made for it. You can use them as mains as long as they are away from your TV. If you use them in that way you can put your receiver in stereo mode and also enjoy them for music. Good luck.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
SDAs are not shielded, but you could shield them if you REALLY wanted to. And SDAs do make great front 5.1 or 2 channel HT speakers because of their 3D imaging and sound stage.
