Best Value SPL Meter for < $100?
Tour2ma
Just did a thorough search, and after an hour or so of reading, I picked up a lot of good info (much of it from Doc.... no surprise, but many thanks), but no answer to my question.
Seems most folks have Radio (Rat) Shack meters and are satisfied, but Doc mentions having to compensate readings on the low frequency end and eyeball an average.
Question is whats the best value in an SPL meter for $100 or under?
Thanks in advance .
Thanks in advance .
More later,
Tour...
Vox Copuli
Tour...
Vox Copuli
Post edited by Tour2ma on
I believe its like this, Rat shack analog for 30 or digital for 50, anything better will be much more then a hundred, I might be wrong though... depends on how precise you want for the subwoofer spl's i guess, The Rat shack one suits me fine.. E-bay search for spl or sound pressure meter will show you alot of models and prices in your range for sure, good luckMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
The Rat Shack digital suites me fine. With C-weighting on slow response I can get a good average and compensate by adding +2dB.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
The RS model is a veritable BARGAIN for $35. Yes, it is inaccurate below about 50 Hz, and it gets worse as it gets lower. But the good thing is it is quite accurate above 50 Hz and is fabulous for general system calibration. Plus, there are published correction factors for it if you are doing some low bass sweeps.
You can't touch this meter for anywhere close to the price.
I have a B&K meter at my disposal at all times, and it is professional grade and superbly accurate at all frequencies (it's been factory certifed twice now and I calibrate it regularly with the included tone generator). But have you priced B&K meters??!! Geesh!
Get the RS model, definitely. I like the analog for $35."What we do in life echoes in eternity"
SVS -
Thanks faster, kberg and Doc...
Going to pick one up today...More later,
Tour...
Vox Copuli
