Need advice
stevew2023
stevew2023 Posts: 14
edited December 2008 in Speakers
Hi All,
I have an Onkyo 605 hooked up to an assortment of speakers. I just ordered the PSW111 sub and I am looking for some satellites type speakers to go with it. I am thinking about the RM85's but am open to suggestions. My room is 9.5 x 21 and the ONLY place to put the tv is tucked in one of the corners (where it is now). The seating area is on the opposite wall so we are between 9 and 11 feet away from the tv depending on where you are on the couch. There is no room for a big sub so I plan on putting the PSW111 behind the corner tv stand. One reason I went with that one was it is downward firing. I was thinking of the 85's because of the two wide dispersion RM8's that come with it.
Any other suggestions for this odd setup?
Post edited by stevew2023 on
