38% rule
SlowcarIX
SlowcarIX Posts: 887
edited November 2008 in Speakers
http://www.realtraps.com/art_room-setup.htm
THE 38 PERCENT RULE
The placement method used here is based on the "38 percent rule" which theorizes that the best listening position is 38 percent into the length of the room, when measured from either the front or rear wall. This offers the best compromise of peaks versus nulls for any given room size. For 2-channel listening you'll get the flattest low frequency response by sitting 38 percent of the way back from the front wall. However, this is not practical in many home theaters, especially those with large screens, because that puts you too close to the screen. Fortunately, you can get the same benefit by sitting 38 percent of the room length when measured from the rear wall.
Please understand that 38% is one theoretical best location to begin measurements, but it may not end up the best place to sit due to other factors - wall properties, speaker location, speaker type, furnishings in the room, and a host of other conditions that can affect frequency response. The only way to know which location really is most flat is to measure the low frequency response at high resolution using software such as ETF, FuzzMeasure, or Room EQ Wizard..................
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
