Rti 10
The RTi10 was rated at 300w max and i want to know if it's the peak or continuous? i'm about getting the RTi10 for my Carver A-500X power Amp. i got a pair of JBL rated at 400w but couldn't handle my Parasound HCA-1500A. the power amp blew up the horn tweeters and a speaker below the horn tweeter i don't know what you guys call it by. 4 pieces of the 2 floor speakers were gone. the volume was not even close the half
my carver power amp rated at 250w/ch
Post edited by bbq on
Yeah, I am pretty sure 300W is max peak power on the 10'sHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
wutadumsn23 wrote: »Yeah, I am pretty sure 300W is max peak power on the 10's
so continuous is around 150w ? -
My Sunfire hasn't bothered my RTi12s. I think you should be fine.Samsung 52" Flat Panel LCD
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus -
I have not had any problems with my RTi-10s behind the amp in my sig. However I would be surprised if I have ever pushed them at a continuous 200 watts for any length of time. I don't think any type of listening would require that much constant power over a ling period of time. I think you will be fine.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
I wouldn't worry about feeding them too much power.....my 8's do just fine with my Adcom and I really push them hard when the wifey's gone.:DLiving Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Here is a link to the RTi10 specs____________________
Pool: Atrium 60's/45's -
I have had my RTi10's hooked up to a lot more available wattage than that. Using Carver amps as well. So long as you have clean power and you are not amplifying distortion, you'll be golden.
Under powering a speaker is far more detrimental than overpowering. Just keep in mind, when you hear distortion, TURN IT DOWN!!! With the Carver amp, you should be able to make your ears bleed before you reach the speaker's threshold of power. I'd also like to welcome you to Club Polk.
Not quite- we don't recommend our speakers by "peak" or "continuous" since it's EXTREMELY difficult to know exactly how much power is going to your speakers, unless you've got specialized test equipment and are running test tones. Music is very complex and highly dynamic (even very compressed material) and amplifiers also have peak power. That being said, the "continuous" rating of our speakers is lower than the "max amplifier recommended" rating but the peak is higher.wutadumsn23 wrote: »Yeah, I am pretty sure 300W is max peak power on the 10's
So an amp 250 watts per channel will fall within recommended amps of the RTi10. Is is possible to still blow the speakers? Yes, depending on the volume and material going through them. As another poster said, if playing loud, keep a sharp ear out for distortion or signs of speaker distress.
If loud is the OP's #1 goal, perhaps some PA type speakers should be considered. They're more efficient, are designed to play loud and project and will be more reliable than home gear (but won't sound as good).-Eric
-Polk Audio -
Eric, you can call me Tom. I'm not "just" another poster bro'. :eek:....As another poster said, if playing loud, keep a sharp ear out for distortion or signs of speaker distress.
Sometimes I actually do know what I'm talking about. Sometimes, that is.....
