Polk RTA 12C Cap Rebuild
wattcraver
Hello everyone.Just finished these.I bought them in 1987.Fried the drivers and replaced them with the wrong type.Had them mothballed till now. Now looking for origonal repacements before I re-Fire them up.I believe the 4 0hm Mw 6503 were the origonals? The Solen caps should make them sing.
Post edited by wattcraver on
Looks very nice. Replace those resistors, and you are good.
Welcome to Club Polk
Ben -
OK thanks Ben.Bypass the poly switch too right?
wattcraver wrote: »OK thanks Ben.Bypass the poly switch too right?
It is a personal preference, but most agree with bypassing(with a jumper) the Poly switch. I also can't tell from the pictures. Do you have some small purplish brown caps on the boards? There should be 2 on each board rated at 750pf. These can just be removed.
Edit: Here is a link to the pic. The small circled cap between the big cap, and the inductor is a 750pf cap.
Ben -
are there the ones? On C2 and C5 .Connect their terminals?
Thanks Steve -
they be the ones... I just cut them off on my RTA-12Cs... made the speaker sound smoother
thanks Ben. connect the wires together right?
just remove them;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
a photo of the purpley thingy.
Thanks for your input Ben -
Guy's it's late (for me) and I'm kinda tired,, but the "thingy" in the above picture is a "mica" isn't it.. the blue thingy in a few pic's before is the poly,,,right?JC approves....he told me so. (F-1 nut)
okay,, I went back and read the entire thread,, the poly's you can "jump",, but the mica's can just be removed,, no jumper? Is that correct? Thanks in advance.JC approves....he told me so. (F-1 nut)
okay,, got it,, would that hold true on all x-overs that use the mica? Reason I ask,is I'm going to re-visit some 2.3 tl x-vers next week. Thanks--georgeJC approves....he told me so. (F-1 nut)
@wattcraver could you kindly list all the components you used so that I can also rebuild my crossovers? I'm clueless about the parts and will order them to have a technician help me solder them. Thank you kindly.
